Question about Frigidaire GLTF2940ES Front Load Washer
My machine wach but do not spin a the end. - Frigidaire GLTF2940ES Front Load Washer
    President:
  • 1,554 Answers
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it awayMy machine wach but do not spin a the end. - 1a4b866.jpgront panel.
Take the door lock and switch assembly out of My machine wach but do not spin a the end. - febd08e.jpg and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or My machine wach but do not spin a the end. - 27a1c27.jpgit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the dooMy machine wach but do not spin a the end. - 0bdb8ce.jpgswitch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Posted on Oct 04, 2010
Very loud on spin cycle
Do not buy Daewoo waching machine
Feb 16, 2014 | Washing Machines
The agitator in my washing machine is trying and notting all of the clothes up, resulting in the machine becoming unbalanced. I have taken the lid off and wached what happens and the agitator only seems to...
Is this a GE Washing Machine? This sounds like one, it sounds like the shifter coil has failed, this it's not locking to engage the agitator. So it's basically stuck in spin mode, this way, even though the tub does not turn.
Mar 12, 2011 | Washing Machines
The waching machine won't do anything when turn to rinse or wash, it only starts to rotate when turned to spin? the machine is only 2 1/2 years old
Whats the exact brand and model.Is it front load or top load.Is it showing any error code on display or any flashing light error code.Is it draining properly or not draining.Also is it making any kind of noise when turned towards spin mode.------------------- Keep updated with the details.Thanks.Helpmech.
Jan 30, 2011 | Kenmore Kitchen Ranges
If your washer washes and drains but does not spin, you need a new door lock mechanism. Not too hard to fix yourself.
Jun 27, 2010 | Frigidaire GLTF2940ES Front Load Washer
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Hi i have hitachi SF-110CJ waching machine how can i cotrol the water temperature before starting the waching process
i have an error code f9 and washing machine stop spinning and dont turn , how can i fix it and where can I buy spar parts , i am from lebanon , west bekaa
Jan 19, 2010 | LWScientific LW Scientific Variable-Temp...
I WANT TO ASK ABOUT THE FUNCTIONS OF INDESIT WIXXL 146 WASHING MA
instruction book http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WIXXL146-GB-Hires.pdf
Jun 10, 2009 | Washing Machines
Rinse and spin
there is a safety switch on the top...and when you close the lid it pushes down on that switch. investigate that switch and see if its just corroded or needs replacement...i have that same problem when i leave the lid open on my washer...then it works fine when i close it...so im figuring that your's thinks its still open. I hope this helps you out ! and give your wife a hug 8-)
Jun 05, 2009 | Washing Machines
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
1,794 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
