Question about Microwave Ovens
I just bought the Farberware Digital Thermometer (the one with the probe and wires) and i cant figure out how to turn it off.
I am cooking a roast beef dinner for Christmas I bought a 13lb chuck boneless and I need to know how long to cook in in a traditional oven.
5 After browning the roast at a 500°F temperature in the oven for 15 minutes, reduce the oven temperature to 325°F. To figure out the total cooking time, allow about 11-12 minutes per pound for rare and 13-15 minutes per pound for medium rare.
Really, you need a probe thermometer. Leave it to rest for 15 minutes after you take it out of the oven, loosely tented with foil. I am a chef!
how long to cook Google Search
Dec 24, 2016 | In Microwave Ovens
Instructions for reheating
same as for cooking. Get yourself a probe thermometer. Reheat on full power until the internal temperature is 165'F. Don't use the microwave with the thermometer in the microwave!
Aug 12, 2015 | Microwave Ovens
Digital temperture gauge where should readings range and how much varation should occur when door is opened ( cause and effect)
You cannot place a digital thermometer or even probe into a microwave oven cavity that is switched on and cooking, without danger and damage!
Feb 13, 2011 | Microwave Ovens
Hi I bought a Temp. sensor probe from Sears the part I need is #316217001 and you guys keep sending part#316490001. These 2 probes are similar but have different connections the one I need is a female...
The part numbers have changed. You have the correct replacement part.
You will have to cut the ends of your wires and use wire nuts to attach the new probe sensor.
Jan 06, 2011 | Frigidaire Microwave Ovens
I bought a Taylor Weekend Warrior digital thermometer 806E4L. Did not receive any instructions.
You can download the Instructions from Taylor's website: http://www.taylorusa.com/media/IBs/806E_ib.pdf
Dec 18, 2010 | Microwave Ovens
I used my Polder meat thermometer in my gas grill. The fat off the meat cause flames to touch the probe. When I looked at the read-out it said 406 degrees F and then HI degrees F. Now it just reads HI...
It is possible that the therrmometer has over shot the limit set on it .It can be spoiled because the hat was in direct contact with the probe and has resulted in the failure of the unit.
Aug 27, 2010 | Microwave Ovens
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
Farberware v-blade mandoline slicer instructions - nothng in or on box - how do I use and put together
I bought a faberware V-blade Mandoline slicer and I would like to have an instruction manual for the blade usage please
Jun 21, 2010 | Microwave Ovens
Microwave Ovens Logo
462 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
