SOURCE: Lost Dominator Garage Remote
Hi There,
If you can handle a screwdriver and a pair of snips, I think you may find this item on ebay useful.
Item number 380001856331
Hope this helps
Cheers.....Dave
SOURCE: Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
SOURCE: Programing limits on a Grifco MK3 Garage door Operator
You can get manual from the link below
Garage door
SOURCE: How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
SOURCE: My Chamberlin remote garage door opener stopped working.
Try this website for a possible solution
http://www.bearcatco.com/helpgifs/liftmaster_troubleshooting.html
