Question about Epson Artisan 710 AllInOne InkJet Printer
I have an epson artisan 710 which displays the message "a printer error has occurred. turn power off and then on again. for details, see Your documentation or epson.com." the documentation is unhelpful and epson's technical support is not open/available..
I just had the same issue but with the 810, which is basically the same. What I had done before that happened was turn on the "Automatic Head Maintenance", then after turning on the printer again the next time the error happened always a few seconds after it started...really frustrating.
The solution was turning off the "Automatic Head Maintenance". Do this as soon as you have access to the menu, because after a few seconds it will show the error and the touch menu will not work anymore. So as soon as the touch menu shows press Setup > Maintenance >Automatic Head Maintenance and turn it off.
Please reply and let me know if it works.
Posted on Oct 16, 2012
  • 4 more comments
  • RTRAADM Feb 09, 2013
    JOHN, EXCELENT SOLUTION,. IT DID WORK ! THANKS.
  • Janet Feb 11, 2013
    That worked for me too! I thought it was the waste ink counter, but when I tried to reset it, it said it was not time. Glad I found this. Thank you!
  • cafedave
    cafedave Feb 11, 2013
    This worked for me too on an Artisan 800! Thank you SO much for saving my printer.
  • Brian F Sep 03, 2013
    This worked! thanks!!!
  • Ron Gonzales
    Ron Gonzales Jan 02, 2015
    I have a Artisan 835 and there is no "auto" head maintenance all maintenance is manual
  • Jerry
    Jerry Sep 01, 2015
    I tied it but it goes to the error message before I can complete it. Bummer. Have no clue of what to do now.
    Problem Solver:
  • 6 Answers
Reset the waste ink counter
you can check the counters value here - http://www.EpsonReset.com
Posted on Mar 27, 2011
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Posted on Dec 17, 2013
  • mitchell5265 Apr 29, 2014
    Thank you all for you inpu, BUT i do not even get to the menu b4 the error code shows.
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
I get the message "printer error has occurred" and please turn the printer off and on repeatedly with no change. This is the Epson Artisan 835
My Epson Artisan 810 repeatedly would give me the printer error message with the only option to turn off the unit and turn it on again. Over and over it would give me the printer error message. With the unit off, I opened the cover (like you would to replace the ink cartridges) and forced the CD tray all the way out like you are about to load a CD for printing, closed the cover, then started the unit up again. For me that did the trick. It went through it's normal 60 seconds or so of set-up, then worked fine ever since. Not sure if this will work for you, but it worked for me.
Dec 29, 2012 | Office Equipment & Supplies
My Epson Artisan 710 is showing that a printer error has occurred. It says turn off and turn on again, but when I do the same signal appears. What is wrong? It h
This could be because of several reasons.
At what point does the printer error-
With start up
Before any operation
on head clean.
on ink charge.
Check there is nothing loose inside and that the printhead is not jammed.
Welly250
Jun 27, 2012 | Epson Artisan 710 AllInOne InkJet Printer
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Why does the printer (EPSON Artisan 710) print out a sheet with writing on the same side when I choose double-sided priting?
test it with 2 pages of text, one page with an "A" on it, then the 2nd page with a "B" on it. once they print out, flip them over and run them thru again to see which side of the paper is being printed on during a pass thru the printer.
Mar 03, 2011 | Epson Artisan 710 AllInOne InkJet Printer
My epson 710 artisan gives an error message that there is a paper jam or is out of paper, when I try to print a photo, it feeds through 2 blank 4*6 photo papers. There is NO paper jam when I check it, and...
Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
Jul 24, 2017 | Epson Artisan 710 AllInOne InkJet Printer
The display on printer is 'check ink tank' however i cant get the ink tanks to move so i can check nor can i get the maintanance option to come up on my display ,,, please help
turn power off the on to get printer to start initialising, as soon as it starts to move away from the home position turn off power again. Ther carriage can now be moved by hand. When you have checked your cartridge reconnect the power and allow the printer to reinitialise.
Please rate the help++++Thankis fore using FIXYA
Oct 12, 2009 | Office Equipment & Supplies
Epson Artisan 710 AllInOne InkJet Printer Logo
2,942 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
