Question about Troy Garden
Runs only when you toggle between choke and run
    President:
  • Troy Master
  • 1,545 Answers
In this mode, you are keeping the fuel mixture richened. You may only need to adjust the carburetor (if you can) to get the machine to run right. Older Troys had splined carb adjusting screws (Zama carb) and some have D-shaped screws (Walbro). There are tools for sale on E-bay that fit these screws...or you can fashion a homemade device on them and adjust....aluminum tubing or the metal crimp end of an electrical connector (the plastic collar can be forced down over the head of the carb screw allowing you to turn it). Properly adjusting the carb on these requires a lengthy explanation. If you get to, and can turn the screws, don't turn them more than 1/4 turn either way. Do it while the engine is running to notice the resultsl
Posted on Oct 04, 2010
Put choke to run it pops put choke half way runs good
dirt or water in carburetor.Choke helps suck more gas in engine to run better.
Dec 28, 2013 | Garden
My honda vtx 1300 will not run with choke all the way in but will run with the choke half way in. what is the problem?
If your bike will only run with the choke half way out it's starving for feul. You have a clogged jet. By choking the bike you cut off the air and allow more feul to run through the carb.
Oct 30, 2012 | Honda Motorcycles
My briggs and stratton mower runs rough but when I toggle choke on and off it runs better for awhile
have to use choke means fuel problem. Check your fuel cap vent, fuel filter. Fuel solenoid opening with key turn on. Remove hose from carb.and see fuel runs out.
Mar 10, 2012 | Craftsman Garden
14" CRT 3.5 hp tiller,
Make sure your Air cleaner is not obstructed. Clean it!
Check your spark plug for the proper gap. Adjust your
LOW speed throttle screw. It may not be getting enough fuel flow. Check your fuel filter screen (Inside your gas tank). Good Luck
Sep 19, 2017 | Craftsman Garden
How do you shut it off?
Just put the choke on full and it will choke off. Both of my chain saws have a toggle switch that will interrupt the spark by grounding it. You cannot start the saws with out throwing that switch to on.
But you can just pull the choke on full and the engine will choke off.
Dec 01, 2010 | Garden
Blower will only run on full choke ryobi ry08578
They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
May 06, 2010 | Ryobi Backpack Blower 25.4cc
I need to know where to run foot parking wire,hand parking wire and how do I hook up toggle switch to play video while driving.
you dont need to run the parking wire just put in toggle switch and run red wire from toggle switch to skinny yellowish or greenish wire not the speaker wire and run the black from toggle to black ground from car and deck and flick the switch and watch whatever you want when u drive
Dec 27, 2009 | Alpine IVA-D310 Car DVD Player
Homelite back pack blower
not enough info - when was it used last - does it have spark- does it have compression etc
Oct 23, 2008 | Homelite Consumer Products Backpack...
Garden Logo
159 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
