Question about Oster Microwave Ovens
How do I remove the oil reservoir to clean it?
    Genius:
  • 1,416 Answers
We had same issue. My husband just unscrewed and removed the metal plate from the bottom of the unit looking for a solution.
The reservoir cannot be removed. The heating coil is permanently attached (welded?) to the bottom of the reservoir.
It is obvious, now, that the reservoir is not intended to be removed.
Ignore the statements in manual that say the oil reservoir is oven safe and not to remove it until it's cool. They do not apply to this model
thanks.
Posted on Oct 03, 2010
Fan noise after temp has increased
Possible that the fan has worn out,filled with dirt or possible that the leaf is rubbing against the frame.
You can remove , clean and reset, with a drop of oil.
Jan 25, 2013 | Belling Microwave Ovens
I have a cv615 Miele Coffee Machine. The water reservoir was not inserted properly and water leaked into the bottom of the machine (drip tray). We got the Water System Fault message, so we removed the...
just use your hair drier to dry out the remaining water.Before doing anything remember to unplug the device.Remove the tray and other such attachments and let it to dry by itself for a day or two.this should solve the problem.never plug in the device till then.
regards.
plz. rate this
Jul 04, 2011 | Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
How do you clean a Tim Hortons home coffee maker. This model has the heated water reservoir with a pot of hot water always ready
UNPLUG IT FIRST, SAFTY FIRST
LET IT COOL OFF,
EMPTY THE WATER AS MUCH AS POSSIBLE
THEN CLEAN WITH 409, OR MR CLEAN, OR WINDEX WITH
A LITTLE BIT OF VINEGAR ADDED ( ABOUT 3 ~ 4 TABLESPOONS )
TO HELP IN CUTTING THE GREASE
THEN BEFORE YOU PLUG IT IN, ADD SOME WATER TO THE TANK,
PLUG IT IN, RESET YOUR CLOCK { IF YOURS HAS A CLOCK }
AND ENJOY !! dd
Feb 05, 2011 | Microwave Ovens
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
If you can find this product: (Or order it online)
el-4.jpg Picture: http://www.sanishieldproducts.com/images/el-4.jpg To find a distributor: 800.528.3149
Shower Tub & Tile Cleaner
  • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
  • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
  • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
ELIMINATE" TUB & TILE CLEANER 32 oz.
  • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
  • Biodegradable
  • Removes soap scum, scale, hard water deposits and body oils
  • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
It is carried by Ace Hardware $6.49 ea
An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
Link with picture: http://milo.com/32-oz-eliminate-shower-tub-and-tile-cleaner (out of stock!)
THIS WILL Clean it.
Kelly
Sep 10, 2010 | Microwave Ovens
R.kerr
Fan some times makes ratteling noise when it is old and dusty. If you know how to open it remove the fan put some oil in the bearing of fan give external supply to fan and run it for 5 mins. clean the ventilation behind fan if noise goes by oil it is good or replace the fan.
Nov 12, 2009 | Microwave Ovens
What product should be used to lubricate the support wheels under the glass turntable? Sucessive cleanings of the glass has not eliminated noise from the wheels during operation.
Use silicone spray, never an oil nor oil based products. The silicone spray has a carrier that evaporates after spraying, leaving only pure liquid silicone behind. It is non-toxic and non-flammable once the carrier has evaporated.
You can get silicone spray at hardware stores, and most cans come with a tube that assures you get silicone only where you intend to.
Sometimes, the noise is from gummy buildup on the wheel axles. If you can remove the wheels (some are attached to removable rings), try soaking in ammonia and hot water then scrubbing lightly with an old toothbrush. Then rinse well. If this is the cause of your problem you won't need the silicone spray.
Mar 22, 2009 | Microwave Ovens
GH5184XPB 3 microwave sounds strange when starting
Unplug your microwave. Open the back remove and oil the fan motorand clean the fan or replace the motor.
Dec 19, 2008 | Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
