Question about Dell Latitude D531 Laptop Motherboard with Discrete
The laptop was working just fine, then the screen went black, the only light is the power light, no bios at boot just power
  • 37 Answers
Try reinstalling the ram. If no change connect to an external monitor and see if it works on that. If so you have a power to screen problem on the laptop lcd.
Posted on Oct 04, 2010
I switch the power on power light comes on fan starts as if to boot then nothing, no screen and no keyboard lights
Does BIOS messages appear, or is the screen absolutely black?
If you see BIOS messages and then black screen, you should go to BIOS and choose your boot devices correctly. If there is no screen do the following tip:
1) Turn off the laptop.
2) remove the battery.
3) click and hold power button for about 30 seconds to discharge the circuit from motherboard.
4) then install the battery again
5) and click power button.
See what happens. In many cases it helps.
If there is still black screen, you should check your laptops RAM. In many cases removing and then installing back the RAM helps.
Oct 19, 2013 | HEWLETT-PACKARD HP 630/P6200 Notebook
LCD Monitor isn't recognized
it is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
Jun 07, 2008 | Compaq Armada M700 Notebook
I recently bought a dell latitude xt2. It kid currently running windows 7 professional. I installed the new BIOS for it (A13). It restarted and the opperating system screen came up. Shortly after the...
The BIOS flash was ok, or you never would have seen windows boot up.
This is not a driver problem.. Are the lights staying on when it's plugged in, if not it's a bad charger and the battery is to low or dead. Have you tried to boot into safe mode, tapping F8. There is a video connector, plug in a monitor, borrow one if you can, if it works and the OS boots and windows run's, the screen is bad.
Mar 30, 2013 | Computers & Internet
Was working on my laptop and the screen went black screen and shut down. then i went to power up and nothing black screen.
Open back cover of laptop then reconnect the battery and RAM memory. Make sure RAM memory is working fine. When you power up the computer press F1 or F2 or del or ALT +F2 key to enter in bios then load optimal defaults settings then check. IF you are not able to see bios setup or any display and after reconnect RAM and battery still not working then it is better to repair it at authorised service center because it has some motherboard related issue. Let me know if you need further assistance. Thanks for using FixYa.
Aug 09, 2010 | Computers & Internet
Dell E510 desktop was fine. Went to start again and yellow light on tower. Keyboard and mouse won't work. Screen is black. Unplugged waited 10 min. And turned on - yellow light still on.have xp.have...
check if your booting device is working fine... and see the booting device in the BIOS.. if it is not found there, try connecting the same in other PC as a slave..if there also it does not work, the device might have gone
Jun 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Black screen with cap lights on no boot and no bios
Can you get to safe mode? Usually F8 at boot will let you go to safe mode. It sounds as if it is not getting that far in the boot up. Try removing the hard drive and attempt boot up. If still nothing on screen it may be the motherboard or a power problem.
Apr 22, 2010 | Dell Inspiron 1521 Laptop
Hp pavilion dv6810us -- the screen went blank suddenly (no hint of a problem) and can't get it back to normal. I've forced shut off and turned back on (4 times over two days)...still black screen. All...
if it was the video card ...it will appear something on screen like Bios...when accessed..and affect only the installation ...I suspect the lcd connection
so...assuming is nothing inside...take a look on this tutorial
http://www.laptop-repair.info/laptop_screen_repair.html
Nov 09, 2009 | HP Pavilion dv6810US Notebook
Everex StepNote VA4103M
ALL depends on what part of your screen went...
What Symptoms did you see before the screen went ... if any..... (like Lines, Colors, Blank screen with light, black screen with No light, etc...)
Can You Plug An External Monitor In the Laptop To See If You Get External Video????
Do You Get A Backlight?? If Not, Do You Have A Display going but no light???
Or Is It Just Black Like it has no power to it... if the latter is true, you really need to connect it to an external video source to see if your video card / chip is shot..
Nov 19, 2008 | Everex StepNote VA4103M Notebook
Toshiba EA60 laptop wont go in boot sequance, its stop after toshiba logo and gives a black screen with blinking curser in top lef corner
Its probably not the BIOS but the board warping beneath the CPU Socket or similar.. Dont flash it (BIOS) or it will probably kill the chip. Let me look up the model number...
Feb 12, 2008 | Computers & Internet
Dell Latitude D531 Laptop Motherboard  with Discrete  Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
