Question about Cozy (W352E) Heater
Cozy heater Wow234 whistles and blow warm air this is a New Heater tried to contact the company for a answer will only say the contractor needs to contact them who installed it but i can't get the contractor to do this THANK YOU
  • 59 Answers
Cozy phone number is 502-589-5380 ask for tech support very helpful.
Posted on Oct 22, 2010
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
How to open Cozy gas heater
See if you can blow out the dust with compressed air. Make sure you get ALL the dust out...that dust could ignite & start a fire!!!! If you can't, don't use the heater. Be sure to re-assemble per original design; or if you can't, don't use the heater!
SAFETY FIRST!!!!!!!
Nov 14, 2013 | Cozy Enclosed Front Console Heater 70,000...
Cozy WOW 234 wall direct vent makes loud whistle noise and the two pipes in the heating chambers are hot the third pipe is cold. This is a brand new heater. It throws air but luke warm only
remove the back panel and check the blower for loose screws or debris like sealant tape. and the third pipe is the fresh air intake.
Sep 20, 2010 | Cozy (W352E) Heater
The Cozy Console Pilot flame has been off less than a hour today 07-07 2010 can we wait till the spring time to put back on or call the Gas- company?
Hi, if you are saying that its off now and is it OK to leave it off until spring, yes it is. If you want it to stay off, you can also shut the gas off at the flex line that supplies gas to the unit. Just turn the small handle to the off position, this is just for added safety.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
The heater pilot goes out when the wind blows outside of the wall where the heater is installed. The heater is only six months old, so the thermo-couple is OK.
You mention that the thermocouple is OK, has it been changed or tested? This $4 part is usually the first thing to fail and I have found bad parts right out of the package. If I were you and I would contact the installing contractor to have them check out the following: Is the vent termination located as per manufacturing instructions (away from interior adjoining walls), Are the vent parts installed correctly, replace the thermocouple under the warranty, and check to make sure the pilot is both good and strong and it is hitting the thermocouple where it should. I have these heater installed on the top of Mount Washington where the wind blows at over 60 miles an hour and do not experience a pilot outage due to wind. The interior design of the venting system combats the wind effects. Good luck to you.
May 06, 2010 | Cozy (W352E) Heater
Pilot light whistles
Get the pilot light changed. Its the only way to stop it, there is a blockage in it and you cant get in the pilot lights to remove them
Jan 04, 2009 | Cozy (W352E) Heater
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Heater blows cold air
With the car warmed up,feel the heater hoses,are they both warm/hot near the firewall in the engine compartment?If they are both warm/hot,then the heater core should have circulation through it and it may be a "blend door" issue in the heater a/c assembly.If they are not warm/hot then the heater core could be dirty and plugged up and needs to be flushed.
If the above does not help,a drain and vacuum of the cooling system and vacuum refill will remove any trapped air.
Sometimes,clamping off the top rad hose and holding the engine rpm at 2000 rpm will force trapped air out of the heater core.(Watch temp gauge when trying this)
Lastly,a NEW thermostat doesn't mean its working correctly.
May 18, 2017 | 2005 Lexus SC300
Cozy (W352E) Heater Logo
Top Cozy Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
