Question about Kodak EasyShare Z740 Digital Camera
No flash after 2 years
Any idea where to send the camera for a new flash bulb? Camera is now 2 years old, over 40,000 photos. Now the flash has refused to work. Pics are fine in regular light, but need the flash. Looking for suggestions on where to send and estimated cost to repair.
Thanks
  • 2 more comments
  • Bobby Russell
    Bobby Russell Aug 14, 2008
    no flash after two years
  • Anonymous Oct 27, 2008
    My flash started flashing really bright like it was going to burn out and sure enough it did. I hae only had my camera for about 6 months!!!!
  • spdoble Nov 08, 2008
    I have the exact same problem. The camera is great, but the flash stopped working a couple of months ago. There is nothing in the manual about this problem, surprisingly.
    Any suggestions are appreciated.
  • Missin Flash Dec 04, 2008
    I LOVED my camera for about 2 years! It still takes great outside pictures, but the flash doesn't work. I'm torn between purchasing a new one or replacing the flash at close to the same cost. Was wondering which is better, what others have done? How long will the replacement flash last & what's the life on the new ones?
Sounds like you might need a new bulb. I just looked up on kodak.com They have all kinds of parts but the labor to fix it can be expencive says it about $138.00 to fix the flash.
Posted on Jul 27, 2008
My Nikon CoolPix S560 has worked great since I bought it about 2 1/2 yrs ago. I know how to set everything, the battery is fine and charged. Natural light photos are fine. Just recently in the middle of an...
Yes, the flash can burn out or the flash circuit can short out. You can send it in for service but, since it's out of warranty, it will be very expensive. B&H photo has a refurbished one for $70. If you send yours in, what you will get back is a refurbished one....they do not bother to fix point-and -shoot cameras. Your choice.
Jun 13, 2011 | Nikon Coolpix S560 Digital Camera
Flash of my Canon PowerShot SD1100 IS not working at all
Has the camera been dropped at all? It may need a new bulb. Most camera stores replace them rather cheap.. But if you want to do it yourself..
How to Replace Your Digital Camera Flash Bulb Like any light bulb, your camera flash bulb can blow at any time. The rest of your camera might be state of the art, but the flash bulb itself is relying on some pretty old fashioned technology. Unlike a light bulb, however, replacing a flash bulb can be a little difficult. Depending on the type of camera or flash you have, some dissection might be required.
Step 1: Choosing the Bulb There are literally dozens of different shapes, sizes and connectors used for camera flash bulbs. These will typically vary depending on the manufacturer. However, be warned, many manufacturers will use different types of bulbs in different cameras. Just because you have a Fuji camera, for example, doesn't mean you can buy any Fuji flash bulb.
Step 2: Safety First Camera manufacturers will never advise you to replace the camera bulb yourself unless you know exactly what you are doing. This is because your camera's flash uses very high voltages. A capacitor will be charged up in order to fire the flash. This capacitor can stay charged for months, if not years. If you're not confident doing this job yourself, then you will need to take it to a camera repair shop.
Sometimes if the camera is too old, you might consider using it as an excuse to upgrade it for a newer model rather than repairing it.
Step 3: Dismantling the Camera Now, you will need to dismantle the camera carefully so that you have access to the flash bulb itself. This may be time consuming and nerve-wracking. One false move could end up breaking the delicate plastic case of your camera.
Once the camera is dismantled, you should then discharge the capacitor safely so that you can continue to work on the camera.
Step 4: Removing the Old Bulb Most bulbs are soldered directly onto the circuit board. In this case, you will need to use a soldering iron to heat up the solder at the back of the bulb and carefully pull it away from the board. This can be difficult, as you need three hands to do it properly. With the old bulb removed, try to clean up the solder pads as much as possible so that the new bulb can fit properly.
Step 5: Replacing the Bulb Push the legs of the replacement flash bulb in position through the holes in the circuit board. Then, using a soldering iron and some solder, fix it in place. Be as accurate as possible to prevent shorting out the circuit. With the bulb in place, cut back the legs of the flash bulb so that it doesn't stick out too far from the board.
Step 6: Reassembly With the replacement flash bulb fitted in the digital camera, you will then need to reassemble your camera. This will be easier if you kept all of the screws in a safe place.This is the one occasion where it's a good idea to assemble before testing simply because of the high voltages involved.
Step 7: Testing Now, put the battery back in the battery and try taking a photo with the flash. Check whether it works; if not, you will need to investigate the cause of the problem
Nov 03, 2010 | Canon PowerShot SD1100 IS Digital Camera
Easyshare Z8612 IS Digital Camera: My flash bulb has blown and I need to know how to ...
May 17, 2010 | Kodak Easyshare Z8612 IS Digital Camera
Flash on EasyShare DX4330 stopped after 7 years
Most likely the capacitor or xenon flash bulb is bad. If you're a techhie of sorts, you might be able to fix it yourself, just make sure you discharge the capacitor when you open the camera up (in case it's still good, and charged). With the low prices on digital cameras today, it would probably be better to buy a new one than have it repaired, and keep this camera as a backup.
Mar 29, 2010 | Kodak EasyShare C875 Digital Camera
How to replace bulb in flash for a Kodak z710
Dec 31, 2009 | Cameras
Flash stops working
The flash bulb may be broken. Try contacting Pentax to get it fixed.
Jul 15, 2009 | Pentax Optio T10 Digital Camera
Flash
Hey MBK2032,
The bulb should be able to be replaced by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they should be able to send it out for service. If the camera is less than a year old the repair will most likely be no cost to you. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 11, 2008 | Nikon Coolpix S1 Digital Camera
My camera c633 takes photos but flash wont work????even with new batt???
It is eathe the bulb or the flash circuit. if you are going to fix it yourself watch out for the flash compasitor. If you are going to send it in watch the cost. It sould be fairly cheap to have fixed.
Dec 31, 2007 | Kodak EasyShare C633 Digital Camera
K100D flash doesn´t work
My camera with the dodgy flash is holidaying in Japan as they sent it to be fixed - not sure how old your camera is but I am trying to see if this is an issue that occurs with the camera model.... given that there are only two of us to date I am thinking that we may have just struck the jackpot :(
Dec 27, 2007 | Pentax K100D Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
108 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
