Question about Acer Aspire One PC Notebook
Computer loads and gives me options to start normal and safe mode and couple of other options. No matter what i pick its starts to load windows and and start all over again
    President:
  • 2,291 Answers
Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with Reg In Out Registry Cleaner and PC Optimizer
Posted on Oct 04, 2010
My computer says its restarting but it hasn't and it wont shut off
Hello, if the Windows operating system, then wait as the operating system upgrades.
Nov 11, 2016 | Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
When I boot up my laptop, it asks me 4 options. Start windows normally, safe mode, safe mode with command prompt, and safe mode with network support. It doesn't matter which one I pick, but when the laptop...
To start your computer normally you must choose either of that options but the only thing you must choose is the start windows normally so that all the settings from the previous working settings will be applied in your windows start up.
Dec 25, 2010 | Toshiba Satellite L45-S7423 Notebook
How do i turn off safe mode
Most computers when you boot it up give the option of "Boot Menu" upon the first few seconds of powering the machine on. Look at the screen and see if it reads Press F1 or F2 for Boot Menu. From there you can toggle off the safe mode option. Sometimes it's the delete key or alt key for some other computer providers as well.
Hope this helps,
Marty
Nov 27, 2010 | Computers & Internet
I have a IBM thinkpad T40, while working on it, the laptop shut down and started to reboot. but only got to a point where it said could not find operating system.after a couple of times tring to reboot it,...
Whilst booting up have tried tapping the F8 key to get into the safe mode menu and either select the last known good configuration option or the safe mode option to load the operating system to then try and determine the cause. Should this suggestion not work a safe option to recovering your data is to buy a USB hard disc drive docking station, whip out your hdd, slot it into the docking station and retrieve your files using another PC. Repairing the operating system using the XP disc on boot up sometimes works but also trashes your personal data if it's on the C drive and it reloads the o/s.
Sep 23, 2010 | IBM ThinkPad T40 2373 Notebook
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Computer crashed, won't go to windows
When you start you computer, after the bios flash. press the F8 on your keyboard before the Windows start loading. You should have an option to select to go to safe mode.
Select the safe mode option only. See if it will load the Windows under the safe mode option. If it did load the Windows under safe mode. There is an issue loading the driver of your Windows O.S. that i why its not booting under the Normal mode. Sometimes this is cause also by a Virus on your computer. You can run the Anti-Virus program under Safe mode to check for viruses
To fix this you may need the Original Disc of Windows O.S.
You can reboot the computer. Load the disc make sure that under the Bios option the CD drive is the first boot. Then save it.
after rebooting. Follow the on screen instruction on how to repair the O.S. There should be an option to repair the O.S. when you boot the computer using the Windows O.S. Disc
Note:
If you could do a backup of your files, do it first before repairing the O.S.
If it will not resolve the issue, you will have to reformat your computer.
Sep 09, 2008 | Computers & Internet
Hp laptop
windows is thnking that you have a problem with the system
start windows in safe mode and troubleshoot and see what the problem is if all else fails you might have to to a system restore
or take it into a tech and see what they think
hope this helps
cheers
Jul 20, 2008 | HP Pavilion dv1000 Notebook
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
Acer Aspire One  PC Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
