Question about Refrigerators
I have a frigidaire side by side refrigerator. Recently water started collecting at the bottom of the freezer unit and eventually seeps out the bottom of the door. All other operations of the unit seem to be working normally. There is no obvious water leak so I suspect a problem with the evaporator during defrost cycles. Is this likely and how can I diagonose it for sure? Thx
  • 1,314 Answers
Sounds like your defrost drain is stopped up its under the evaporator clear it and you should be ok
Posted on May 27, 2008
Leaking water periodically under the refrigiater
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Frigidaire FRS26H7C Side by Side...
I have water collecting on the bottome of my side by side refrigerator on the frigerator sided un the crisper.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Sep 17, 2010 | Frigidaire FRS6R5EMB Side by Side...
I have a Frigidaire Side-By-Side refrigerator Model #FRS26ZSHB3, that is collecting water on the bottom of the interior of the freezer side. I have to remove the ice every 2-days, otherwise the water leaks...
Drain system is clogged.
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Jul 15, 2010 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire Professional 22.6 Cu. Ft. Counter-Depth Refrigerator - Model: FPHC2399KF I have ice that is collecting in the bottom of my freezer. My understanding is that this ice is caused by a buildup...
There is a chance that the drain hole is pluged or clogged with frozen ice.This can usually be cleared with hot water to melt the ice then dry off any remaining water with a towel.
the drain is located in the bottom rear of the freezer cabinet just behind the panel with the vent holes
Jul 06, 2010 | Frigidaire FPHC2399KF (226 cu ft) Side by...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!!
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
Frigidaire side by side refrigerator problem
is it coming from underneath or out of the units refrig or freezer bottoms ??
Jan 26, 2008 | Frigidaire FRS26R4A Side by Side...
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
