Question about Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Does the sharp Aquos LC-52 support HDCP? I have Dish Network and for some reason can't watch any HD PPV channels, Dish Network says it's a TV issue. Can you help?
    Scholar:
    New Friend:
  • 73 Answers
DISH Network blocks multiple video outputs on all PPV and most premium content to prevent recording, and they will tell you it is a TV issue. Ensure that your receiver only has one video cable coming out, to only one device (ie HDMI to the TV) and try again.
Posted on Mar 16, 2015
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
Highdefjeff
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
SOURCE: Sharp AQUOS LC-60C52U
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Posted on Sep 29, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 1779 Answers
SOURCE: Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Posted on Jul 09, 2009
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
We have Dish Network VIP722 on only one HD tv at this time. When recordng HD PPV, we are unable to change channels without getting message that recording will stop. Menu>Preferences>Record...
This is a problem that many have. If you are recording on TV1, and the receiver is in dual mode, then you are only able to watch what you record. But you can set your recording to TV1, and then put the receiver into single mode, and switch from the recording to live TV.
Becki Barned
DISH Network Customer Service
Mar 05, 2011 | DISH Network ViP722 DTV Receiver /...
I need a dish network code for a 52" Sharp Aquos.
Hi deidrapleasmy name is Mike Houston of DISH Network and I was going over your post and thecodes for your 52" Sharp Aquos are 628, 739, 521, 629, 741, 679, 112, 605, 625,111, 608, 740, 526, 585, 607, 652, 654, 655, 658, 669, 670 and 674. I will sendthe link to help with the setup for the remote to TV. http://www.dishnetwork.com/SupportSection/remote-control
Feb 14, 2011 | DISH Network IR Remote Control
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
DISH remote will not work for the first 10 minutes when the TV is turned on; so, I have to watch the channel I was watching before I turned the TV off. It seems to work fine after the initial 10 minutes.
Is the TV new? Is it a HD TV? If it is Either a 9Samsung LN(R/S)## Series , Sony Bravia/XBR# Series ,Sharp Aquos (New Models) , or Phillips ##PFL Series than the issue your haveing is what we call IR Remote Response Lost. its a light that cuts on and off that makes any IR remo not work some period of time. You have too call the TV manufactuer or use the manual for assistance. If you need details on how too fix it let me know!!!
Nov 01, 2009 | DISH Network IR Remote Control
Hooking up a dish network to my tv
Well, I don 't have that T.V. but I can tell you that you may have to go to your menu and look for your channel setup and change it to another channel output. If that doesn't help then have it search for channels.
Jan 30, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Polaroid Model TDA-03211C
Our tv sharp aquos LC 52 GD^U 52 in. HDTV LCD plays a narrative along with the closed captioning on selected channels, especially channel 2. We cannot get it to turn off and it is annoying to the point of wanting to return the tv. Please help.
Jul 14, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Help it wont stop changing channel by its self?
Sluger,
Check for a stuck remote button. Take the batteries out of remotes and see if that stops it. If you have Dish Network, let me know.
Dec 30, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Size of screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
Dec 06, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-52SE94U 52 in. LCD HDTV Logo
331 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
