Question about Maytag Neptune MDE5500AY Electric Dryer
One of the three bars in the tumbler is coming loose...I think one of the screws is out and it makes a noise...still works but we would like to put the screw back on and fix it. How can we do that? THanks!
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum, motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 04, 2010
I have a Kenmore dryer. The fins are real loose, make alot of noise, catch socks, etc. How can I fix it.?
If the first three digits of the model number are "110." remove the lint filter from the top and remove the two exposed screws. Then you can insert a putty knife or similar tool into the gap between the front panel and top, about 2-1/2 inches in from the sides, and push in on the retaining clips. While pushing on a clip, simultaneously lift on that corresponding top corner, and the top will release to swing up.
This will expose the outside of the tumbler. As you spin the tumbler, each spot where a baffle is attached will come into view. After making sure there are no items inside the baffles (coins, pins, etc.), tighten the holding screws.
Dec 30, 2010 | Kenmore Dryers
The tumbler makes a terrible noise - I'm sure it's just a coin or a screw rattling around in there. I can't figure out how to get inside to look around the tumbler to see what it may be. And once...
Open the door and look inside - yes, you can see everything inside the drum. Sometimes buttons, especially the metal ones on denim pants, can make a pretty good racket.
If you don't find any foreign objects inside the drum, and the dryer makes noise even when it's empty, it may be time to change the drum rollers or the belt tensioner pulley. It's also remotely possible that there's something batting about in the blower housing, but if that is the case, it would probably be a screw or something broken off of the ductwork, or the blower itself is loose on the shaft. Post back if you need instructions for checking the mechanism underneath the drum.
Nov 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I replaced my clutch and throwout barring from the clutch kit. I didn't turn the fly wheel. And the pilot barring didn't go with my model car. So I didn't use it. The car is now put back together, and it...
3 quarts should be enough fluid. Did it make the noise before you replaced the clutch. It sounds like a bearing in the trans. It's not the pilot bearing. A pilot bearing would make noise when you step on the clutch and then the noise would go away when you let out the clutch. Can you describe the noise? It sounds like a bearing in the trans or a problem with the throw out bearing.
Oct 30, 2010 | 2000 Mitsubishi Mirage
One of the tumbler fins inside the dryer has come loose and fallen out. How do I repair it
gotta open it. usually screws are inside dryer. 3 screw hold it. make sure u unplug unit b4 putting hand inside
Feb 12, 2010 | KitchenAid Dryers
My key won't unlocke my driver's door. Just spins the key hole. How do I fix, or replace, the keyhole tumbler. I need to know how to take off the intertior door panel, and how to get to the door's insides...
Sounds like maybe the linkage came undone. You can take off the door panel and inspect it, you'll notice right away whether the linkage came undone or if the tumbler is bad.
Roll down the window first, and if you have a handle for your window, put a flat screwdriver between the panel and the handle and gently pry it away from the door panel. If you look behind the handle, you will see a clip that needs to come off to get the handle off. Push it off with a screw driver (This can be a task!)now, put a screw driver in between the panel and the door and pry. Don't pull too hard, and any screws that you find going along the panel or in the panel (check the interior handle and arm rest) need to come out. The door will make a popping noise when you pry it, which is normal. There are spreader clips on the panels which keep it "suctioned" to the door, you're just pulling the clips out of the door. Work from the bottom to the top. When the panel is completely loose, lift the panel up at an angle. The panel "hangs" on the top lip of the door. When you put it back together, hang the panel on the top lip, line up the clips and gently "pop" it back into place, then put the screws back in.
Oct 29, 2009 | Dodge Neon Cars & Trucks
Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Dec 31, 2008 | Maytag HYE3658AY Electric Dryer
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Washing machine making a clicking noise.
The problem most likely is something stuck in the water port of the drain pump. My machiine would not empty once and I found a 12 penny nail that had made its way from the drum though the drain line to the the pump, where it was wedged against the impellers that spins to draw out the water through the pump. The pump is located in the front right bottom of the machine and accessible by reoving the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump. Then do a better job checking your pockets.
Sep 01, 2007 | Washing Machines
Maytag Neptune MDE5500AY Electric Dryer Logo
47 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
