Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or backward.
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Posted on Dec 18, 2010
    Problem Solver:
  • 13 Answers
Maybe there is something wrong with the motor. You change a new battery, so it is not for the batteries. More from Marshell Green Power CO., LTD, http://www.marshell.net
Posted on Sep 09, 2011
  • 692 Answers
Zippidi Check the freewheel lever and make sure you can't push the scooter easily. Turn off the switch and turn back on and try to make sure it moves. Hope this helps you
Posted on Oct 03, 2010
My fortress 1700 dt used I got it home put on charger and all it did was click red blue green all night no charge are battery's shot the drive lever is in position has been sitting for a year
sitting for a year isnt good for them
D lever position would have flattened the battery to dead flat
over night should have recharged the battery to full
new battery required (shop around for a good price)
May 27, 2016 | Blue Health & Beauty
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
Jan 12, 2013 | Electric Mobility Health & Beauty
Got the scooter for xmas last year -- has been used approximately 5 times. SHows battery is fully charged. Will not go. Need help.
hello,,i'm not overly familiar with these but,,here goes,,,,if it is reading fully charged,,but it will not go,,,,if you have an electrical tester,,,plug the red probe into the red wire connector on the battery,,,,and the black one to the black connector on battery,,,,,just to be sure charge gauge is reading correctly,,,,,,if it is indeed fully charged,,,,now go to where you engage the power,,,,whether it be a pedal,,or a trigger on the handle bar,,,,,you will have to check all connections to be sure one has not come off,,,,or got to lose to make a connection,,,,if all looks ok there,,,,check the wires that go to the motor ,,, from the battery,,,,make sure all is secure,,,,, if it has gotten wet,,,check for any corrosion on all your electricals,,,,,,and clean ,,,,,when your doing all this,,,,,also check for a broken wire,,,,,or stripped wire,,,, hopefully these steps will put you in the right direction and back to riding,,,,, JOEL
Aug 22, 2010 | Razor E100 Electric Scooter
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
When i plug up my charger to my electric scooter it says that it is fully charged but when i unplug it it doesnt move at all
I had a similar problem. When scooter purchased, gave it the full 8 hr charge. Was great. Husband did not bring batteries n that winter from unheated building. If left in cold a trickle charger needs to be on it. Easier to take out and bring in.
Same thing happened. Would charge and said fully charged but one battery(has 2) had a dead cell from being out in the cold. Took to batteries plus(very reasonable) had it checked and purchased.new one. Put in and gave it a full charge. Wonderful ever since. Use it at horse shows to run from trailer to stalls to arena and all over. Constantly forget to turn switch off and still comes through for me. It appears to go into a sleep mode when you forget to switch off. When back to trailer to sleep plug it in. The first 2 days of a 7 day circuit didn't plug in but then started to whenever I took it back to trailer as the strip sign says on platform. Duh!! Love it, love it love it!!!
Jun 11, 2009 | Electric Currie EZIP 500 Scooter
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
2,075 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
