Problem with my LG monitor L194WT
You will have to increase the referesh rate first and then go into thegame and reset the resolution. The resolution bit is secondary. Ifincreasing the refresh rate works, then you dont have to change theresolution :)
So if i increase the refresh rate,i need to load the game and then ALT + TAB and change the resolution in the windows or what?
  • Anonymous Mar 18, 2014
    need manual that describes resolution and refresh rate
    President:
  • 2,712 Answers
First change the referesh rate for your monitor. If that works, then you dont have to change the resolution. If that does not work, try increasing the rate again. Once you can get the game, then try to change the resolution from within the game options, if necessary..
Posted on May 27, 2008
I use an LG L194wt-sf monitor and I just installed windows 7 on my desktop computer which was using windows xp formerly. i optimal display is 1440x900 and its not available in the resolution settings what...
Try to update the display driver on your monitor.They should have a website for that.If not your monitor may not be able to display at that resolution.You can also check out your video card.Good Luck.
Aug 02, 2012 | Samsung Computers & Internet
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
Hello everybody! I am trying to solve this problem..I have a bad resolution for the lg monitor.I am using win7 with a nvidia gts 250. So win7 can't find the drivers of the lg monitor.And i have...
google --drivers for LG monitor model ????
and download the driver suitable for your monitor model
after that go to control panel o the pc , select display and then adjust the pixel settings to suit the monitor
Oct 24, 2017 | LG L194WT 19" LCD Monitor
How to open a 17" LG L194WT LCD monitor
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194WT%20&kategoria=&kat2=all
I usually open it at the bottom edge first and work it all the way around using thin flat blade screw driver.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 17, 2010 | LG L194WT 19" LCD Monitor
Unable to detect 1440 x 900 resolution after change of cables
Try updating video drivers to be sure, but once you go over 3 meters, the video signal can degrade, causing a loss in the PnP signal to your monitor. Try setting the resolution manually.
Dec 28, 2009 | Samsung Syncmaster 940BW LCD Monitor
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
Digital shut down
Try making sure the video card's Display Settings have the Screen Resolution set to a level that are compatible with your LCD monitor. Try starting at 800x600, applying the settings and testing them, and moving up slowly until it doesn't work anymore, then stay at that same level.
Jun 11, 2008 | Gateway FPD2275W LCD Monitor
You will have to increase the referesh rate first and then go into the game and reset the resolution. The resolution bit is secondary. If increasing the refresh rate works, then you dont have to change the resolution :)
May 27, 2008 | Computers & Internet
LG Studioworks 900B 19" CRT
Try using the minimum supported refresh rate. Also set the resolution to the minimum that will please you (for example 1024x768). See whether the lag still occurs. (Use the nVidia control panel to change the settings). If there is no lag, you can increase the resolution step by step (if you feel the resolution is too low) and keep on increasing until lag occurs. Set the res just below that value.
Nov 28, 2007 | LG Studioworks 900B 19" CRT Monitor
Computers & Internet Logo
484 people viewed this question
David Payne
David Payne
