Need wiring schematic for model# 397haw036080 Bryant furnace. unplugged harness to repair, lost paper, to put it back. thanks, chris
  • 1 more comment
  • cld5272 Oct 03, 2010
    i need the wiring harness diagram from the control board to the other components of the furnace(ie, gas valve, blower, ect...) Bryant model # 397haw036080. furnace is 28yr. old. thanks,chris
  • cld5272 Oct 04, 2010
    just need a diagram to be sure i get the wires from the harness in the right places before i turn it on. bryant furnace, model # 397haw036080 made in 1982. thanks
    thank-you for getting back to me. if you can find a pdf file on it, that would be great. its my screw-up, but i cant afford service call. thanks again, chris
    President:
  • 2,777 Answers
That is going to be very difficult to find online, I am checking for you now, but I know for sure you can just request one from Bryant for free. You may want to just do that, but I will continue to search for it here for you. If you want Bryant's number it is 1-800-428-4326 and they can help you with this issue in the mean time.
Will keep looking though for you,
Tim
Posted on Oct 04, 2010
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    The call to Bryant would be free for sure, they can send you the PDF, so far it does not look like it's available online anywhere but still trying.
    Tim
    Genius:
  • 1,478 Answers
I will advice you contact the dealer for the wiring schematic of your device. This is the best option that you can use to get the wiring schematic for your device.
Take care.
Posted on Oct 03, 2010
  • 857 Answers
We are having an issue with our furnace. It reaches temperature, clicks off, clicks back on, clicks off. It happens intermittently. We can't tell if the problem in with the furnace or the thermostat.
An intermittent problem can take patience and time. Process of elimination too. If you are unfamiliar with servicing and repairing a gas furnace, you may want to leave that chore to a professional. Now, what exactly is coming back on after the set temp is reached? Blower only or is it firing the furnace also. My experience says it's just the blower. This is caused by... Furnace overheating, then shutting down, then bringing blower on to cool it down. Probably not your scenario. It's possible the control board is acting up. Highly possible that you have a high temp limit with a loose connection, or needs to be replaced. Schematic will call it HS or LS, something like that and it should have 2-6 of em. Possible that the G wire from the t-stat is shorting to R, and bringing the fan on. Try posting more info? Model & serial number. Fan cycling or furnace? Have you checked new t-stat installer configuration? Hope this helps! And work safe
Oct 31, 2017 | Heating & Cooling
Bryant plus 80 furnace no fan/ operation , yellow constant flashing light code , power to furnace was rerouted during remodel and since then furnace stopped working. Any suggestions ?
You need to have/ know the "fault code" chart for that specific furnace. Count the number of flashes and refer to chart. Look on the inside of the furnace blower door or other panel. Also look up on internet and print it off. If the furnace was allowed to run during the remodel it voids the warranty automatically. Read the installation manual.
Try resetting the electronic board by turning the power off then back on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Mar 29, 2017 | Bryant Heating & Cooling
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
I also need a wiring schematic for a Coleman 3500A816 furnace
What are you wiring? Possibly we can help.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 24, 2017 | Coleman Heating & Cooling
Honeywell thermostat
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Aug 10, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
415 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
