Question about GE JE520BW Microwave Oven
I HAVE TO SELECT THE POWER BEFORE CHOOSING TIME
    Genius:
  • 1,416 Answers
what need to do is to put off the power from the wall allow the oven to cool the put it on again and make sure that you star at the appropriate place/ pointin other to avoid damage on the oven element
rate this solution if it help from any way
thank you.
Posted on Oct 03, 2010
Sharp microwave model R-218L(W) I changed the burnt fuse after a power outage. It now powers on and works but not cooking
Hi and welcome to FixYa, I am Kelly.
My experience is here:
http://blog.fixya.com/index.php/2010/05/award-winning-service
Most likely the fuse failed as a result of a power diode or capacitor failure and not a a result of a power failure. You can see the diodes here:
http://www.appliancezone.com/SearchProducts.aspx?ID=WB27X608&x=12&y=9 If the diode or capacitor fail the unit will not fire the magnetron and will cause the internal fuse to fail. One these smaller 800W units if someone operated the microwave empty it often caused the diode to fail.
You have to ground the capacitor multiple times with the BLADE of a screwdriver then disconnect the diode from the capacitor to test it with a meter. In one direction it will read continuity and in the other direction (leads reversed) it will read open. No other reading is acceptable. Opens or shorts in both directions = bad diode.
To test the capacitor you probe bothe terminals with a metsistance scale of R X 1,00 or preferably R X 10,000 watching for a brief jump in resistance and then the meter drifts to infinity each time the meter leads are reversed. No jump or an open or ground for that matter = bad capacitor. These are the 2 main reasons microwaves stop cooking.
I think you will find the diode is bad.
Thanks for choosing FixYa,
Kelly
Kelly
Jun 22, 2011 | Microwave Ovens
Does not turn on all the numbers on panel are zero's and blinking, did try unplugging still nothing
Flashing zeros are a sign of a momentary power loss. Usually you also get a Pf error also. Not always....
Try this and if it does not work let me know.
Press Stop / cancel
Press clock
Set time
Press clock
Attempt normal use.
Kelly
May 22, 2011 | Sharp R-209HK Microwave Oven
Won't turn on after disconnecting the power code from the wall socket,
Press stop / cancel
Then press Clock
Enter time
Press clock.
It should now be working normally. If not respond here again and I will help you.
Kelly
May 12, 2011 | Whirlpool MH6150XM Microwave Oven
How to set the clock
Without a model number this is big time shooting from the hip because they are not all the same.
Press stop cancel. Then clock. SET TIME Press clock again.
Kelly
Apr 08, 2011 | Microwave Ovens
Pf code flashing on oven
PF = Power failure.
Usually all you have to do is press stop / cancel, then Clock then CLOCK again. After the time is set your microwave should work normally again.
If this does NOT correct your problem I need a complete model number in any future responses.
Thanks for choosing FixYa.
Kelly
Jan 04, 2011 | Microwave Ovens
When I set the time --- it just ticks and nothing comes on
Hello ebrunsw. Generally to set the time you push clock and then set the time AND then push clock a second time. Joe
Thanks for choosing Fixya!
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I am having a problem with my Panasonic Microwave oven. the operating panel is a touch type one. Now whenevr I am pressing any button, I am not getting any beep sound nor the display panel is showing any...
Hi and welcome to FixYa. I am Kelly.
This can happen when there is a power failure. Usually there is a PF in the display but you can also get 88:88
Try this first: Press stop / pause or cancel then clock and try and set the time. If at that time you do not get any beeps your control board most likely has a problem. To dig deeper if you wish to have more assistance I need your complete model number to possibly troubleshoot.
Kelly
Oct 21, 2010 | Panasonic Microwave Ovens
How doI change the power on my microwave?
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Jul 06, 2009 | GE JES1855 Microwave Oven
How do i change the power on my microwave
  • Press "Start"
Jul 06, 2009 | GE Microwave Ovens
GE JE520BW Microwave Oven Logo
20 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
