Question about Nintendo Wii Console
Wii will not turn on - will replacing the battery make any difference?
  • 45 Answers
I am guessing by battery you mean the external power pack. Most likely your power pack is dead. Some people with the same problem have said that unplugging the power pack for several minutes to an hour, then plugging it back in worked just fine. It is also what Nintendo Customer Service will ask you to do before considering repair.
Posted on Oct 03, 2010
Wii fix guide
Try this link it may help. If not there may be an issue with the console or controllers. Try the controllers on a different wii. Try a different controller with your wii. Wii Remote Not Working or Syncing Correctly Wii and Wii mini Nintendo...
Aug 21, 2014 | Nintendo Wii Remote Controller
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
We received the wii system w/ a battery charger included ,but there were no instructions as to whether you can recharge batts. w/o having the them in the unit ,what the red,green light means what the...
Installing the Batteries
    Important Note: If you would like to use rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
  1. Remove the battery cover on the back of the Wii Remote and insert two AA batteries, using the plus (+) and minus (-) guides in the Wii Remote's battery compartment to insert the batteries in the proper direction.
  2. Be sure to insert the minus (-) end first when inserting new batteries, and remove the plus (+) end first when replacing the batteries.
  3. Replace the battery cover.
  4. Go to the Next Step (Wearing the Wrist Strap) >
  1. Place your hand through the wrist strap and hold the remote firmly in your hand. wiiremotewrist1.gif
  2. Slide the strap lock towards your wrist so that the strap will not fall off. Do not over tighten the strap lock so that it's uncomfortable. It should be tight enough to hold the wrist strap in place. wiiremotewrist2.gif
    Go to the Next Step (Syncing the Wii Remote with the Wii Console) >
Jan 23, 2011 | Nintendo Wii Console
When wii is turned on the start screen that shows the remot and asks to hit a comes up in three different languages can not move pass that? Remotes not responding
try syncing your remote by doing the following (and make sure batteries are good)
Jan 16, 2011 | Nintendo Wii Console
Wii remote is not turning on
You probably need to re-sync the Wii Remote.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Source: http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Oct 20, 2009 | Nintendo Wii Console
My Wii Remotes Arn't Connceting To My Wii
I think you need to sync the remotes. Try this. Undo the battery cover and you will see a red button. turn on youre Wii and if you look at the front of the Wii you will se a littile panal. open it and you wil find another red button. Press it and press the one on the remote.
Jul 28, 2009 | Nintendo Wii Console
Wii will not power on
Make sure the batteries are not dead in the controllers for turning it on.
Next, check all plugs on the console to make sure theyre pluged it all the way if any. Try it again, if it still doesnt work, check to see if your warranty expired yet. Most likely it hasnt. Next call nintendo for support and see if you may have to ship it in. Whatever is wrong with it right now, is nothing that cant be fixed or replaced.
You can also try using a different power adapter to see if thats the problem. If its not turning on, or no lights are, obviously not enough power is getting to the WII. Sometimes the fuse in the power adapters plug in can blow, check that and replace it if needed.
Apr 13, 2009 | Nintendo Wii Console
My Wii board won't turn on
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Feb 27, 2009 | Nintendo Wii Console
Wii remotes
Try changing the batteries. If you have the rechargable battery, then put in some regular batteries and see if that makes a difference. Also try and re-sync the remote to the Wii. Also, make sure the se4nsor bar is plugged into the Wii and not damaged. I hope this helps. Good luck.
Aug 15, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
63 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
