Question about Denon AVR688
I am trying to calibrate the speakers and the error message is "H/P Only". I understand that means Headphones Only, however, i dont know how to change from HP only to speakers....help??
I ran into this yesterday on a customer's unit that was in for repair.Apparently when the headphone jack is removed while the unit is on and A
Posted on Oct 19, 2010
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
After charging my sony reader 600, I have a message: Calibration error detected please restart calibration process. WHAT DOES THAT MEAN?
the touch calibration was affected due to charging in ON condition.switch off your mobile and charge it or try changing a original charger
Mar 20, 2010 | Sony Reader Touch PRS-600
When calibration the system I get error message warning -1 error.
with a push of a button on the remote, it will tell you what that means. it could be a speaker out of phase. check the manual. good luck
Feb 06, 2010 | Yamaha HTR-5790 Receiver
Dell studio xps no sound will come out of the speakers
I assume you mean the internal speakers.
First thing I would try is hooking up a set of headphones. If you can hear sounds thru the headphones then there could be an issue with the headphone jack. (the jack acts like a switch, switching OFF the speakers when you have a plug inside, and switching them back ON when you remove the plug).
If you dont hear sounds thru the headset or speakers, check your device manager, and remove/reinstall your audio driver. You can download the driver at the dell website Support.Dell.com.
Oct 26, 2009 | Dell A525 Computer Speakers
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Realtek Sound device problem
i dont have a volumecontrol
Jun 02, 2009 | Computers & Internet
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
May 31, 2009 | Bose Lifestyle 35 Series II System
Error message on TI-83. What does it mean?
It means that you have put the wrong things together. E.X. String>Equ(x,y) when x dont equal a Yvar. and y dont equal a string number (StrZ, Z=#'s 0-9)
May 06, 2009 | Texas Instruments TI-83 Plus Calculator
Because of Gigaware headphones, my speakers dont work
it sounds like the headphones shorted out the usb on your system, you might try some speakers that are not usb and see what you come up with,,,also check and make sur your sound isnt muted on the master control for the volume
Feb 26, 2009 | Audio Players & Recorders
Compass calibration
Hello. First day I use this device, and have found this tips for compass calibration (as I understand, compass calibration depend on satellite signals - so before compass calibration it's better to get good signals from satellites):
- keep device at horizontal plane (as from message "hold level");
- turn it slow, but not too very slow.
It's better don't turn device, but get device at hands, and turn around himself with it with constant slow speed, and keep horizontal level of device - by this way I have a more accurate calibration, than turn just in hands or on the table.
I hope this will help.
Jun 23, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Denon AVR688 Logo
153 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
