Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Have kenmore 59592992 side by side frid. problems began yesterday when we notices slight smaell of smoke. The circuit breaker was kicked. I unplugged everything in the kitchen and checked the outlets. plugged fridge back in and no other issues with circuit breakers. that was about 24 hrs ago, now notice that the temp is way low. sounds to me the compressor is running but there is no flow of cold air.
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Posted on Mar 04, 2007
  • 213 Answers
SOURCE: Kenmore side by side not cold
the relay overload on the compressor is bad. very common problem. replace relay overload and it will work again. unplug from wall until you replace it.
Posted on Nov 27, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
Yesterday by juicer kicked of the kitchen breaker? Twice.
You may just be overloading the circuit. Easiest correction - unplug something else that's running (or turn off a light) on the same circuit and see if the breaker still shuts off.
But wait - also important - was there any burning smell? If so, this is dangerous. It's a short circuit that occurs when a "hot" wire (black) touches another hot wire or touches a "neutral" wire (white) in one of your outlets. You should not use that outlet and have an electrician look at it. Or it could be a ground fault (similar to the short circuit - when a hot wire touches the ground wire on the side of a metal outlet box which is connected to the ground wire. For either of these, you need an electrician.
Apr 05, 2017 | Juicers
Does this model have a battery backup?
All smoke alarms that connect to your household electricity must be replaced every 10 years by code (NFPA 72). Chances are the device is indicating low battery, but it is time to replace it and all others of the same age. Check your local hardware store or call a licensed electrician to replace them.
Oct 06, 2014 | Home
Smoke burning smell for transformer
YES! You must replace the breaker! Circuit breakers are made to prevent fires from over-current on the line that follows the breaker. If it was smoking, it means that too much current was flowing and it did not trip soon enough. Most breakers, whether they trip at 15 Amps or 150 Amps can handle a very quick pulse of up to 10,000 Amps, but that would not make them smoke: something went wrong. A circuit breaker is cheap. Your safety is not!
Feb 22, 2012 | Electrical Supplies
My freezer is working great but my refrigerator is warm on my kenmore side by side refrigerator model # 59592992
Look for frost on the backside of the freezer. You might have a bad defrost heater. It could also be a bad evaporator fan motor.
May 06, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
Knife touching heating element in water, began smoking
The problem you have is that with the heating element energized with 120 volts to heat the water and came in contact with metal and in water, it may have shorted the element out. It may have just tripped the circuit breaker also. Go to the breaker box and you will find the breaker. It is probably in the midway position. Shut it off hard and back on. It should be fine then. Let me know if that was the problem, and if not we will go from there.
Sincerely,
Shastalaker7
Feb 25, 2010 | KitchenAid Dishwashers
Delta Side Kick table saw will not start,
If there is no response at all, check the circuit breaker on the motor. There is a heat triggered breaker there. That is the most common cause of this. If that is not the case, please update this and we'll look further.
Dan
Feb 01, 2010 | Delta Saws
Gas stove stopped working
Hi . I would begin by pulling the stove out and making sure it is plugged in. If it is, unplug it and plug something else into the plug like a blow dryer to make sure you have power to that outlet. If there is no power, you have either blown a fuse or kicked a circuit breaker. Go to your electrical panel to replace the fuse or reset the circuit breaker. good luck.
Feb 01, 2009 | Kenmore Kitchen Ranges
Kenmore Oasis washer will not turn on
I have the same problem. I used the unit 2 days ago and no problems- just bragged about the unit yesterday and now today it will not turn on and it is no longer under warranty. I also checked to see if power to plug and it is fine. Any suggestions?
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
When I turn on dishwasher it kicks breaker at wall outlet.
if it is tripping the breaker you have a dead short to ground check the water inlet valve on the left side front unplug the 2 wire connector to it and plug it in see if it stays on if you you found your short if not let me know.. but i will need the model # off the unit to get the wiring diagram
Jan 21, 2008 | Kenmore 17439 Built-in Dishwasher
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
97 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
