I have a Coleman furnace in my mobile home, P/N DGAH077BBSB, which was installed April 2007. The pressure switch died in March 2010 and I replaced the pressure switch in April 2010 with P/N 9371DO-HS-0031, which is a 0.18 aperture switch (replaced the 0.15 switch in there previously) but did not use the furnace at all after replacement as the weather was warm by then. Fast forward to October 2010, I changed the filters and turned up the thermostat for the first time this season and it only blows cold air. There are no error codes. Appears to operate normally. Just does not blow anything but cold air. Help!
  • kc2rib Oct 04, 2010
    read this: [url=http://www.ehow.com/how-does_5045697_tro...[/url]
    it says two things may be occurring; either the blower drive belt or a dirty burner which needs cleaned. I would advise that it is a dirty burner as you have not used the furnace in several months. Call a pro.
  • 455 Answers
Hello Maybe the switch is doing it's job.Please inspect the entire exaust/smoke pipe/chimney system for blockage or restrictions/nests.
Posted on Oct 04, 2010
How do I replace filter panels on Coleman mobile home gas furnace after I have changed filters on them? They won't go back in easily
one post only,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman Heating & Cooling
How do I get the panels back on my Coleman motor home furnace? I changed the filters and now I can't get the panels back on
please one post,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman 7956-336p Mobile Home Furnace Gas...
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Coleman furnace
Is this a blend air system? If so, there is an upper & lower control board that communicate to each other, and if the exhaust fan on the roof is out, it will give you intermittent issues. The fan mixes or blends outside air with the return of the air handler, & duals to pressurize the attic. These were installed due to mobile homes built too air tight. Without this fan, your roofing shingles will curl, and your roof decking will bow prematurely.
Dec 22, 2012 | Coleman Mobile Modular Home Gas Furnace...
My furnace just quit working yesterday. It worked fine till yesterday and now its not coming on. I can manually get the blower fan to come on by switching the thermostat from auto to run but there is no...
march 11 2010
Dear Ms.Mrs.
I would apply of your company? I'am a hardworking man, then i can handle any time of job?
Sincerely yours, Michael S. Anuada
Mar 11, 2010 | Coleman Heating & Cooling
Evcon coleman furnace
I have a Evcon mod.# DGAH077BBSB with 4 light flash code
Jan 23, 2009 | Tools & Hardware - Others
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
