Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Top of freezer will not freeze
The top 2 shelves of the freezer will not freeze. It appears that the air is not circulating. This is a brand new freezer.
    Genius:
  • 1,122 Answers
YOUR EVAPERATOR FAN IS STUCK OR BURNED OUT,REMOVE BOTTOM PANEL AND SEE IF BLADE IS STUCK,TRY TO RUN START IT WITH YOUR FINGER,IF IT WILL NOT START REPLACE,THANKS-MIKE
Posted on May 29, 2008
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
Nov 20, 2013 | Whirlpool Freezers
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
The temperature alarm light is on. the temperature is cold emough to freeze bu t some thngs are not frozen especially on the door shelves. the top rack is frosty . while all others are not frosty
maybe you need to reprocess your freezer. theres an compressor oil in the tube causing the abnormality of circulation of freon gas in your freezer. you need to clean up.
Jun 17, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Frost Buildup on Top Shelf lower shelves aren't freezing
This link might help you troubleshoot
Freezer Frost inside Symptom Diagnosis Sears PartsDirect
The lucky solution is if the door seal or inner plastic liner need to be placed/repaired (this lets warmer air into the freezer causing frost and poor cooling).
But you can also see from the link that your symptoms could be caused by other electronic related things...more of a challenge to fix...
Helpful?
Good luck on your troubleshooting
Feb 17, 2018 | Frigidaire Freezers
Kenmore Upright 13 cu.ft freezer- uneven freezing
no it sound like there is a problem with the seal system where the freon is kept this model does not have a fan because is the shelves get frosted so there is a leak or restriction so try calling a tech but i would just buy a new if i was you since to fix will cost about the same
Nov 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
167 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
