Question about Keurig Ultra B50 1-Cup Coffee Maker
My Keurig de-scale light wont go off - Keurig Ultra B50 1-Cup Coffee Maker
  • 40 Answers
SOURCE: My Keurig is not drawing
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Posted on Oct 07, 2010
SOURCE: today,my keurig started to short cup me, and
The water pump is probably starving for water:1. Remove the clear plastic reservoir and set it aside. 2. Look into the hole that the reservoir sits on. You will see a fine plastic screen that keeps debris from getting to the pump. 3. Clean off the screen. You may have to disassemble the bottom of the machine and remove it to do it right. 4. Put everything back together and the short-cup problem will be history.
Posted on Dec 20, 2010
  • 3287 Answers
SOURCE: My keurig coffee maker is flashing the words DE
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Posted on Feb 06, 2011
heatman101
  • 43501 Answers
SOURCE: Trying to de-scale keurig coffee
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: My keurig will not brew a full cup and I have
heatman101
Posted on Mar 01, 2011
Keurig says ready to brew but wont brew. Says de-scale on screen
Run the descale program even if you don't use descaler. You should though for optimum performance.
Mar 18, 2016 | Keurig Coffee Makers & Espresso Machines
Coffemaker not brewing, trying to de-scale but wont brew
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 16, 2011 | Keurig B60 Coffee Maker
I de-scaled my maker twice , it worked for one day then the de-scaled light came on again, now the water will not run through the machine at all
heatman101
Jul 28, 2011 | Keurig Elite B40 Coffee Maker
It says to de scale, ive been running vinegar and water through it but it's having a hard time coming out and still says de scale.
heatman101
Jul 21, 2011 | Keurig B60 Coffee Maker
I ran a cycle of vinegar through special edition brewer and it continues to say de-scale after doing scaling. it won't pour water sometimes and has to be turned on and off to get it to pour water. ...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 14, 2011 | Keurig Platinum B70 Coffee Maker
I can;t find manual and I want to clean my keurig coffee maker
You may be able to find the User Guide for your Keurig machine here:
http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help
Your brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar. Full de-scaling insturctions can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Mar 26, 2011 | Microwave Ovens
Takes a long time for the water to heat and many times I have to push the power button on just to get one cup. Then when I have gotten one cup and want to make another it shuts off. It sounds like the...
Depending on how long you have owned your B-40, It may be time to de-scale, even if your de-scale light is not on, it may take more then a once and done de-scaling proses on your part, if your B-40 is less then a year old call Keurig, for a free REPLACEMENT.!!!!
Feb 26, 2011 | Keurig Elite B40 Coffee Maker
I have de-scaled three times and it still tells me to de-scale
i'd love to know the answer to this.. have had my keurig about 2 yrs and i have to descale it everyday.... love the keurig but this is gettng to be a pain
Jan 16, 2010 | Keurig B50 Coffee Maker
Keurig Ultra B50 1-Cup Coffee Maker Logo
375 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
