Question about Dell A215 Computer Speakers
Can not hear sound
Since having my computer reset a few months ago my speakers haven't worked since. They are connected to my computer and I know they work as when i switch them on the green light shows. As soon as they are switched on I can hear a crackling noise coming from them. The volume icon has dissapeared and when I click on 'Sounds,Speech and Audio Devices' it comes up with no Audio device. When going to control panel looking under 'Hardware' it says the device can not start. I have tried un-installing and re- installing the speakers several times and the same thing appears. As you can tell i'm not very technical with computers so any help would be greatly appreciated thankyou.
  • 4 more comments
  • shubhamkumar Aug 07, 2008
    Few days before my computer was formated n since then the speakers are not working.In the control panel when i open sound options it shows no audio devices.
  • Anonymous Oct 11, 2008
    dosent work
  • fer_ard_3 Oct 20, 2008
    a feww days ago my computer was formated an since that i don't hear nothing with my speakers
  • Anonymous Oct 22, 2008
    i cant hear anything but the light is on
  • Anonymous Dec 23, 2008
    i cant found sounds drivers for dell can you help me ok
  • spar57 Dec 25, 2008
    yes I do my email is keithsparks@bellsouth.net
  • 56 Answers
Try going to support.dell.com and entering your Service Tag. Then click on drivers and downloads and download and install the audio driver that they currently recommend for your machine. Sounds like a driver problem and something that wasn't set properly after the computer was reset.
Posted on Jun 11, 2008
I have the same problem
Posted on Sep 15, 2008
I have a Toshiba 50HX70... I fixed the convergence issue around 6 months ago. Now the sound does not work... I turn it all the way up and you barely hear anything... I did move it recently, did I know...
Best best would be to try the following:
Start with taking the back cover off of the tv.
1) Verify if you can hear any sound whatsoever out of the speakers. If so, that would indicate that the speakers are still connected to the circuit board. If not, then trace the wires from the speakers to where they plug on to the board.
2) if you hear sound (hiss) in the speakers, but not the audio signal from your program you are watching, then look to ensure all connecters are fully seated around the RCA jacks in the back.
If those two do no produce results, then could be a solder joint on the board finally failed after moving the tv, or the amplifier for the speakers has failed. If you hear sound though as in step 1 above, i would doubt it is the amplifier IC.
Feb 20, 2011 | Toshiba 50HX70 50" Rear Projection...
Creative Inspire 5200 system won't work
Hi. Check your speaker system with a different audio device like iPod or any MP3 Player using the same jacks. If the speaker system gives out sounds then nothing is wrong with it... if no sounds come out, then you know what I mean...
Try to replace the speaker of your sub-woofer... maybe that can fix it!
^_^
Jun 06, 2010 | Creative Labs Inspire 5200 Computer...
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
Dell no sound
I also have Dell W2600 TV and have sound problems
Dec 14, 2008 | Dell W2600 26 in. LCD Television
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Stopped working
Sorry I don't have a solution, but the speakers have done the same with us. Power comes on, some sound like the wire shorting out, but otherwise no sound. Tried different connection wires, different computers (mac and pc) but no go on any of them. So, I also don't think it has anything to do with you deleting some files.
May 11, 2008 | M-Audio StudioPro 4 Main / Stereo Speaker
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Nov 23, 2007 | Gateway GMAX 5100 Computer Speakers
Speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Oct 05, 2007 | Acer 90.00012.30B Computer Speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Dell A215 Computer Speakers Logo
167 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
