Question about Kodak Carousel 5600 Slide Projector
The projector keeps turning as though it was is in a very quick timer mode when I power it on.
    President:
  • Kodak Master
  • 412 Answers
It is operating in "continuous cycle" mode. It's possible a contact on the slide change camstack has either worn out or an adjustment to that electrical contact point needs to be made. An authorized Service Dealer has the instructions to make this repair.
Posted on Nov 04, 2010
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How can i reset the lamp timer ???? Typ of beamer: Sony VPL-FX51 E-Mail:francois.humbert-prince@vtg.admin.ch
    Connect with power cord and turn the projector to the standby mode.
    Press the following keys on the control panel in the following order for less than in five seconds each: RESET, LEFT arrow key and RIGHT arrow key and then ENTER.(showing in the picture below)
    (NOTE projector must be in standby mode and keys pressed less than five seconds)
    now press power/standby key to ON the projector and check lamp hoursgood_help_1.png
    Jan 31, 2011 | Sony VPL-FX51 Multimedia Projector
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    How do I reset the lamp timer on the Sony VPL-DS100?
    Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
    Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
    Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
    Recently I was using my xv-z90u, I started the projector up and turned it off right away and the bulb replacement lights started flashing and going into a standby mode(two red lights). So I replaced the...
    There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
    Jan 14, 2010 | Sharp Projector lamp Projector Lamp
    Lamp reset timer
    Hi there
    There is basically two ways to reset the lamp timer :
    1. ) On the Projector's physical buttons
    Arrow Keys - Up , Down , Left , Right then Menu and Enter - this should be done quickly whilst the Projector is in standby mode.
    2.) Switch Projector on - Hold in the Up Arrow Key on the physical buttons on the Projector untill a PIP screen appears - then just follow the on screen steps.
    Sep 25, 2008 | LG RD-JT91 Multimedia Projector
    Reset Lamp Hours Timer
    This works on a couple different Toshiba models -- might work on yours...
    Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
    Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
    Bulb Reset issue
    I had the same problem and called Sony, they just said to keep trying what the manual says to do, but make sure the unit is in standby mode. I tried in powered mode and in standby mode many times and it did not work. Then I tried again the next day when the unit had been in standby mode for an extended time period. I hit the four buttons like the manual said, all four in quick succession. I also tried the four buttons in many different sequences from what the manual said. When I powered back up the lamp timer was set to zero, finally! I think having the unit in standby for an extended time was the key. The Sony rep really emphasized the need for the unit to be in standby.
    Oct 01, 2007 | Sony VPL PX40 Multimedia Projector
    Kodak Carousel 5600 Slide Projector Logo
    109 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
