Question about Dimplex Compact Electric Flame Stove Heater
I have a dimplex dfb6016 the problem is it will not work when i turn it on.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Hi, I have the same problem. I contacted Dimplex Customer Support today and was told that it is probably the "receiver board" that quit working ...from looking at the service manual, I think she meant the circuit board. Since my unit is between 2-5 years old, they are sending me a replacement circuit board at no charge w/ instructions on how to install it. Hope this helps! B.
Posted on Oct 06, 2010
Dimplex jazz all switches turns off immediatly
http://www.dimplex.com/cms/publications/7210170100r00_EN.pdf
Apr 20, 2016 | Dimplex Heating & Cooling
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
I have a Dimplex Ritz electric 2000w heater that is only working on the low 1000w setting. When the high setting is selected it auto turns off and there was a funny smell which I am assuming a fuse has...
Yes, it can be repaired, if Dimplex still stocks that particular heating element. It's not to difficult to replace the heating element, just mark all the wires before removing the old one. Also, it will require removing the logs inside the heater, because you will need to turn the stove upside to do the removal and replacement. Contact Dimplex Technical Support at 1-888-346-7539.
Hope this helps you.
Jul 06, 2011 | Dimplex Compact Electric Flame Stove...
My customer just bought a CS 1205 from our True Value Store. The blower on the new CS 1205 does not work. It has been used three or four time. The flame comes on however. What do you suggest?
Before call Dimplex Technical Service (888-346-7539) have your customer turn the Master ON/OFF Switch to OFF. Unplug the fireplace for 12 - 15 minutes. Once plugged back in, have them turn the Master ON/OFF Switch to On and then turn ON each function of the fireplace one at a time. If everything is performing as it should, the unit reset itself. However, if this becomes a recurring problem, they should contact Dimplex Technical Service.
Hope this helps you solve the problem for them.
Apr 05, 2011 | Dimplex CS1205 Electric Compact Heater
Just purchased a dimplex DS5629 electric stove. Plugged it in, but NO HEAT and NO BLOWER. Dimplex is closed for the weekend. NOW WHAT???
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Hope this helps you solve the problem.
Apr 01, 2011 | Dimplex DS5629 Electric Heater
It works for 3 to 5 minutes then stops heating. Turn it off ,wait 5 minutes and the same thing happens? Help
The overload switch is either working as it should or has malfunctioned. Contact Dimplex direct (You can find them on line with a Google search) and talk with their Tech Service Department.
Jan 26, 2011 | Dimplex Compact Electric Flame Stove...
Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Jan 16, 2010 | Dimplex Heating & Cooling
My air heater won't turn on it's a Dimplex DFB6016. What can I do?
call Dimplex : 1-800-668-6663 Ext: 358 These folks can solve your problem and send you replacement parts.
Dec 13, 2008 | Dimplex Compact Electric Flame Stove...
Dimplex Compact Electric Flame Stove Heater Logo
914 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Andee Goacher
Andee Goacher
Level 1 Expert
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
