Question about Zoom 220 HMV 3-Wheel Travel Scooter
Do you require a special batter charger .......or is there a built in charger in the batter pack? if so, I need a power cord..
  • 692 Answers
Jo the Zoom has an off-board charger and if you didn't get one with the scooter you'll have to buy one. Check with your local mobility provider and have them order one for you or call Pride Mobility @ 1-800-800-8586 and ask if you can order one from them Hope this helps you
Posted on Oct 03, 2010
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
Apr 28, 2016 | Samsung Galaxy Tab 2 7.0
Charging cord missing
The charger manufacturer is Clore Automotive. The part number is ESA26 (http://www.cloreautomotive.com/sku.php?id=274).
If you know anything about electronics, you can determine the input voltage and current requirements for the charger and purchase a generic power pack. The cord connection to the charger can be matched and purchased from an electronic store like FRYs.
Oct 24, 2012 | Solar ES1224 Truck PAC 3200 Peak Amp,...
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Need a batter charger for shark vac model v1950. ka12d090015023u. can not find where to get it
I had same problem asn used these websites:
http://www.imshopping.com/question_answer/adapter-cord-for-shark-corless-sweeper-model-v1950
or
http://www.emtcompany.com/ka12d090015023u-ac-power-supply-charger-adapter/101318782.html
Hope this helps, Lisa
Nov 23, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
I have the powershot SD3500IS abd it says i need to change the battery pack what is that and how can i fix it also if i dont have a charer can i charge it with the usb ?
"Change batter pack" means your battery is dead. The camera should have come with a charger in the bok that can plug into the outlet in your wall. It uses a lithium ion battery, so you can't use a regular AA batter charger, for instance. You cannot charge the battery via the usb into your computer.
Nov 06, 2010 | Canon PowerShot SD3500 IS / IXUS 210...
How can i charge my onboard battery offboard? ineed to take the batter off and charge it indoors
Keith You have to remove the seat from the scooter and then lift the battery pack out of the frame. On the front of the battery pack there should be a charger port where you can plug in the charger into the battery pack when you are inside. Plug your charger into the battery pack first then plug it into the receptacle. When fully charged unplug from the receptacle first then unplug it from the battery pack. In other words always have the charger unplugged from the power when plugging and unplugging it from the battery pack. Velcro is holding the pack down so you might have to give it a good yank to get it off the frame. Hope this helps
Oct 20, 2010 | Pride Mobility Products Go-Go Elite...
Windowxp dell 600 lap top will not charge battery or turn on wih ac power do i need a new battery or black sreen does not deytemine ac adapter will not preform best operatings
check first the battery pack... use another batter pack to check the batter if its okay or not... if okay..then use another charger also to check the charger. if the problem is the same you need to open you laptop and check or repair the charger connection or some chips of your unit.
its needed the expert hardware. bring to the nearest computer service center if you can't do it..
Jun 23, 2010 | Dell Latitude D600 Notebook
I have a rca no rtd250 impedance 12 ohms subwoofer. how do i connect it to my yamaha htr 5940.do i need a special cabel where do i get it.
The Yamaha can only drive powered subwoofers. Make sure that the RTD250 has it's own amplifier built in, you won't be able to easily run it off the yamaha if it doesn't.( the powered subwoofer will have a mains cord to power if it's correct) If it doesn't have a amp built in, easiest weay is to buy a cheap powered sub.
Is the RTD 250 the sub fromthe RCA home theatre pack?
Jan 14, 2010 | Yamaha HTR-5940 Receiver
My acer aspire 4310's screen has been "blinking"
Have you changed any hardware components lately???
does this problem still exist if the battery is removed and only the charger connected to the wall?
AC power should still power the lap top for normal booting process,check this first,
if so try
replace the battery or the charger plug is faulty on the laptop
Please let me know the outcome,thanks
Jul 31, 2008 | Computers & Internet
Zoom 220 HMV 3-Wheel Travel Scooter Logo
77 people viewed this question
Top Zoom Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Craig Butler
Craig Butler
Are you a Zoom Health and Beauty Expert? Answer questions, earn points and help others
