Question about Keurig Elite B40 Coffee Maker
Water not flowing through to cup; have already tried cleaning it....
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a Keurig B70
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 06, 2011
  • 51186 Answers
SOURCE: How come water from the water reservoir doesnt go up to the K-cup Portion Pack Assembly Housing?
i have a small wire device that we run thru the water tube when it brews slower than 3 minutes
Posted on Mar 05, 2015
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
How do I get my B60 to put liquid in to the cup I already used a paper clipin nozzle all 3 holes
Remove and clean the fine screen filter on the bottom of the reservoir.
If you leave water in the machine all the time, a clear bio-film will begin to form on all wet surfaces. Feel the inside walls of the reservoir - if slippery - you have this clear bio-film present on the tank. Clean it and remove the filter screen assembly from the tank. Scrub thoroughly with an old tooth brush and check that it is clear before re assembly by placing it under running tap water. Water should flow THROUGH it - rather than around it.
Next, may sure the float in the tank moves easily. It provides a signal to the maker that "proves" there is water present. If stuck in the down position, the maker won't work.
Lastly, only fill the tank with as much water that you need for a few hours. Don't let it sit over night, either. WASH the tank regularly. Some parts of it are dishwasher safe.
Jan 09, 2015 | Coffee Makers & Espresso Machines
Water doesn't want to go through cup when brewing.
There are two tubes/ports that clog frequently. The upper penetrating needle with a hollow center must be cleared with a paperclip end when debris collects in the tube. The lower basket pulls out and that also gets clogged necessitating a cleaning. See the manual for Instructions.
Feb 05, 2014 | Keurig Coffee Makers & Espresso Machines
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
Water won't flow thru to filter or pot. Don't know the exact model but it is a 12 cup self cleaning.
Self-cleaning is wishful thinking. Every three months or so, run a pint of vinegar through it, as if making coffee (no coffee!) then flush with two tanks of water.
Mar 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
Using the k-cup..does not brew the water splashes everywhere
That is because most likely the part that punctures the k cup is most likely clogged, try using Like a paper clip and cleaning out the small hole and should flow. Mike
Oct 29, 2011 | Breville BKC700XL Stainless Steel
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Saeco SUP 021 (Y)
is it the far right lamp that blinking? Then you have to descale your machine.
Is it the lamp in the middle in the bottom row, then you have to open the door and take out the driptray and dregsbox for 5 to 10 sec.
if the water drop flashing then you have to open the steam knob and make a cup of water(tea).
Hope this will help you.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Keurig Elite B40 Coffee Maker Logo
1,296 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
