Question about Cell Phones
I recently bought an lg bliss and it won't turn on. the end/power button won't work at all. i don't know why since i haven't dropped it or spilled anything on it. i've tried charging it and taking the battery out but nothing is working. i need help!
    Master:
  • 473 Answers
Check Battery If low.. Possibility Charger Defect... If not.. Celll need to be replace
Posted on Oct 03, 2010
  • c_rudniski Oct 03, 2010
    the phone will charge and it's charged completely. i believe that it's the power button that isn't working. anything i can do?
Toshiba c55
Try just using the mains power. Remove battery an leave plugged in . If it works it's the battery/ power brick .
Dec 26, 2013 | Computers & Internet
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
I recently bought a Scosche Digital FM Transmitter Model FMTD8/FMTD8R. I loaded my 8GB San-disk flash drive with music but the transmitter won't read it.. doesn't even detect the flash drive being...
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
Jun 11, 2011 | GPS
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
The touch screen doesn't work
here are various problems the lg ks660 touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Press and hold the home button as well as the reset button on the top of the lg ks660 phone to turn the lg ks660 off.
May 09, 2011 | LG KS660 Cell Phone
The screen touch of the lg viewty k990 is no more working, only the three buttons beneath work, what can i do to fix the problem
Was water spilled on the phone? Was it dropped recently? If something happened you might have to take the phone in to a BestBuy for a repair. If this is due to no external damage, water or dropping the phone, you should call LG customer service as they might have a direct download to fix the software of the phone. Should it be hardware related, consult your warranty. Good luck!
Mar 06, 2011 | LG KU990 Viewty
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
Cell Phones Logo
190 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
