Question about Bosch HGS 255 Gas Kitchen Range
Bosch gas range HGS7052UC touch and turn panel not responding. I have tried recycling the power via our circuit breaker. However, the Touch panel is still not responding. Any help is appreciated.
My touch panel is not responding. It just flashes numbers to set the clock. I can turn the dial to set the hour only. Can't touch start...does any
one fix there panel? where and how much it cost.?
Posted on Jun 05, 2012
2 Suggested Answers
  • 210 Answers
SOURCE: LG Kitchen Series Electric Range Smooth touch controls POSESSED!
The is a tough one if there is no tech there. I have not heard of this problem as yet. There could be a loose connection in one of the ribbon cables or it could just be a defective board.
You can try putting it in to test mode to see if it can self diagnose itself.
Press 'favourite' and 'settings' at the same time, 'diagnois' will appear, press them again and the prompts will appear. Note make sure the top surface is clear as well as the oven. If an error pops up at least you will know what is wrong with it. There is also a tech sheet on the back with the fault codes.
side note, do not put alluminium foil on the bottom of the oven cavity.
Sgt 48
Posted on Jun 01, 2008
Digital screen reads F1--oven will not light
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 14, 2010 | Amana ACF3325 Gas Kitchen Range
Oven is showing a f1 error
F1
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
1. Disconnect
has been disconnected, so please double check before continuing.
2. Gain
keypad or membrane switch) ribbon from the ERC.
on. Assemble the control panel back the way it was.
on.
accompanied by a beeping sound).
Dec 14, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
F1 ERROR CODE
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
Nov 22, 2010 | Maytag CWG3100A Gas Single Oven
Model JBGP80 MEV2BC Display panel shows "F1" and emits beeps (very annoying)... while unit seems now to be working fine otherwise. I will check and re-establish any cabling, etc. Meanwhile, how do I...
Sep 16, 2010 | GE JGBP80 Gas Kitchen Range
F1 appeared on the panel screen,my model is MGR5770ADB.Please reply.
HI. Essentially, this will be the result of a failed touch pad. Some models incorporate the touch pad in to the ERC(control board) as a single assembly, in which case, the test I will post below is not necessary. If your touch pad is Incorporated in to the control board assembly, Simply replace the entire Control board. Follow the test below if the touch pad is separate from the control board.
Warning: If you feel in any way uncomfortable with performing this test or making this repair, please contact a qualified appliance repair technician.
Dec 21, 2009 | Maytag MGR5770 Gas Kitchen Range
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F 1 code after using Jenn-Aire electric oven
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem.This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Sep 21, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Timer tone goes off with F1 display
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
6. Wait for at least one hour to see if the code comes back.
Hope it helps.
Thank you for using FixYa.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
All lights on the touch panel are flashing and a continous beeping sound
bosch 700 series range. So far unplugging the range and waiting several minutes to plug back in reset everything like rebooting a computer.
Dec 19, 2006 | Bosch HGS435UC Gas Kitchen Range
Bosch HGS 255 Gas Kitchen Range Logo
387 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
