Question about Kohler K-3386-96 Rialto one-piece round-front toilet with seat and left-han
I have a Kohler Rialto K-3386 toilet. When I flush, water sprays from the top of the fill valve higher than the top of the tank, so water runs down the front of the tank.
3 Suggested Answers
canddplumb
  • 35 Answers
SOURCE: I can't unscrew the bolts on my Kohler 3386 rialto
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
Posted on Dec 03, 2009
  • 83 Answers
SOURCE: After flushing my Kohler 3386
sometimes removing the 3 or 4 screws that hold the top of assemble and separating the assemble will dislodge debri..and adjust the seat so that the water comes out of the small tube into the overflow tube like it should.
Posted on Nov 25, 2010
Does not have flush volume. another issue is it take a long time to fill and a very slow water volume.
Check and make sure the valve on the wall under the tank is fully open, and that the float is not getting hung up on the inside of the tank
Mar 05, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
I just installed a Kholer Rialto toilet and the water doesn't shut off, it keeps running even though the tank fills with water.
My toilet is running, how do I fix it? To solve this problem, you'll want to ask the following questions:
  1. Is water running into the overflow tube? If so, lower/adjust the float valve. By doing this it will float higher closing the inlet valve.
  2. Is the chain too slack or too tight? Make sure the chain has only 1-2 beads of slack.
  3. Has the water in the home or surrounding area been recently shut off for some reason? This could cause debris to come up through the water pipes and settle into the diaphragm seal of the fill valve. Flush out the diaphragm seal.
This is not an unusal problem; here is a video that may provide more assistance:
Dec 16, 2010 | Kohler K-3386-0 Rialto one-piece...
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
After flushing my Kohler 3386 Rialto Toilet the top of the valve assembly shoots water out while refilling the tank wich hits the tank top and leaks down the front. What do I need to do to fix this? ...
Nov 25, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Water squirts from tank while filling
Take lid off and check that the fill tube is in place. If so flush with lid off to see were the water is squirting from, be prepared to clean up water...If you can, do a slight flush. If there is water coming from any where but the bottom of fill valve and the fill tube you may need to replace the fill valve. In my experience, the fill tube is dissconected.
For Diagram
http://www.askmehelpdesk.com/attachments/plumbing/19906d1242687133-shut-off-valve-under-toilet-doesnt-work-fluidmaster-20ballcock.gif
Jul 06, 2010 | Kohler K-3386-0 Rialto one-piece...
Bowl does not fill after flushing
Check the fill line in the tank and make sure it is connected from fill valve to overflow tube. After you flush the toilet it fill's the bowl and tank.
It should be a line about 1/4 ' in size coming from fill valve to overflow tube.
Dec 28, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Water running off and on and comes out from top piece.
you unfortunately need a new fill valve. I say unfortunately because they are expensive, (about $120), for that model and not everywhere sells them. It it was a "regular" toilet, the part would be a any home store and cost about $10. Sorry to be the bearer of bad news. How old is the toilet? You may consider replacing the whole thing.
Aug 10, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Jun 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Apr 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler K-3386-96 Rialto one-piece round-front toilet with seat and left-han Logo
114 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
