Question about ElectroVoice . Speaker
I have the EV sh-1502 speakers ..i am getting crackling from one of the horns..what and how do i fix it thanx
3 Suggested Answers
  • 19 Answers
SOURCE: no sound from EV SH-1502 ER 15" driver
Either the 15" speaker is dead, or the passive crossover inside the unit. The simplest way to identify your problem is to remover the speaker that isn't working from the enclosure, and exchange it with the speaker that is working. If there's no sound still, it's the speaker itself that is the problem. If it works in the other cabinet, then put the "working" speaker in the cabinet you took the "bad" speaker out of, and if it doesn't work, then there's a problem with the crossover in the first cabinet. I believe you can buy a replacement crossover from EV. If it's your speaker, do a google search for "speaker re-coning" in your area - it's cheaper to re-cone the speaker than buy a new one.
Posted on Jun 18, 2009
caroldon
  • 17130 Answers
SOURCE: I have an old set of EV 1502 PA Speakers. One of
The crossover network is a combination of a LCR circuit. since all these arre passive components you will not have a problem to find the actual fault. Since you have confirmed with the drivers, the line in to the network from the speaker wires must be traced for continutiy, use a good multimeter. now check carefully on the PCB-printed circuit board.- for any track damage on it, if so loop and connect. The main driver is usually in parallel to the main line but with a croos over of a cpacitor and a series inductor. This will be the culprit, either it has come off from the PCB or open out by burning off. replace or reconnect. I am sure it can be sorted out easily by your carefully analysis. Hope this helps. Good day
Posted on Jul 20, 2010
I have a VISIO VX37L 2006 TV The audio goes on and off and crackles and sometimes makes a loud horn sound. Please Help!
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 19, 2015 | Televison & Video
Crackle or popping from EV Sx 100+ speaker
test this : Gd bless you
Line noise is feeding in from the AC line. Use an ac line filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 10, 2013 | ElectroVoice Audio Players & Recorders
Crackling in rear speakers of panasonic wireless system sh-fx71 from home theater system sa- btt770
The wireless circuitry is malfunctioning due to a part failure, this is a job for a professional and I recommend a estimate.
Mar 18, 2012 | Panasonic Televison & Video
I have a pair of Peavey Hysis 2 speakers. At a gig on Saturday night one of the started crackling when loud vocals went through. I set them up in the garage next day and the cab that had been crackling...
You have likely almost but not totally fried a voice coil in your speaker. Most speakers get cooked from underpowering, not from being overdriven. What are the speakers rated for and what are you driving them with?
Nov 17, 2017 | Peavey CH1 Speaker
Where can i buy a horn for a ev sx 300? how much?
You don't "buy a horn" as the horn itself is molded into the case and if the case is smashed that is fatal.
If it is the sctive element for the tweeter/mid you are after, the correct terminology is "compression driver". That should aid your search.
It is best to go directely to EV to get an exact replacement for this. Or try to find one at this site:
http://www.loudspeakersplus.com/parent_category/HFCD/High-Frequency-Compression-Drivers/1.html
They vary from about $30 to $500.
Sep 06, 2010 | ElectroVoice Sx300e
I have an old set of EV 1502 PA Speakers. One of my Cabs the 15" driver stopped working... I can plug the Horn and the 15" Driver in Separately and they both work which I think means I have a problem with...
Jul 19, 2010 | ElectroVoice . Speaker
Wiring diagram for horns in a speaker ev eliminator i dual 15's
hi can you please tell me on a ev elimenator horn which out of the wires is the live?
Nov 02, 2009 | Audio Players & Recorders
There is crackling coming from the horn as soon as the power is turned on, the level of the crackle does not alter with the volume control, the cabinet performs fine otherwise ?????
The horn speaker is wearing out. Inside speakers, there is a magnet, the speaker part is attached to a cone that slides over the magnet, They tend to make crackling noises. Try very gently to apply pressure to the horn and then release. If you hear a scratching sound, the horn will need to be replaced
Jun 27, 2009 | Mackie SRM-450 System
No sound from EV SH-1502 ER 15" driver
Jun 18, 2009 | ElectroVoice . Speaker
How will i know if the horn has blown on my ev zx 5 speaker?(there is no top end at all) thanks.
first,try switching to a different output(if this is the left speaker,switch it to the right)if it does the same thing,then we need to pull the back off the speaker.to make sure the crossover is not bad your gonna want to unplug the horn & put a signal to it from your source(do this at a low volume with the bass turned down & trble turned up)if you have sound then there is a problem with the crossover(this is the pc board in the enclosure that connects to the speakers)if not your horn is gone.hope this helps,thanx for using fix.please rate all replys
Nov 17, 2008 | ElectroVoice Audio Players & Recorders
ElectroVoice . Speaker Logo
427 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
