Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dish not clean
The water temp.is 120.degrees rinse aid is full heater is working
  • 868 Answers
Sprayer arms are clogged up.You can fix them by removing the arms and flushing them out in the sink
Posted on May 27, 2008
My dishwasher is not cleaning the dishes as well as it used to. Are there some simple things I can try before calling a tech?
Use a good quality powder detergent.
Check your incoming water temperature, 120 degrees plus.
Use a rinse aid such as Jet Dry.
Start the DW without soap and no dishes.
Once it starts the wash cycle pour in 1 quart of WHITE vinegar and let it finish the full wash cycle.
Then load up with dishes and powder detergent and run a load.
Jan 13, 2011 | KitchenAid Dishwashers
The dishes do not rinse properly--despite rinse
run some calcium lime and scale remover throught the unit on an empty wash cycle just to get rid of any build up that may be there.
turn the rinse aid down to about half way.
also check the phosphours content of you washing agent.
there is a lot of factor involved with leaving film on the dishes, it could also be residual soap content that is sticking to your dishes.
reduce the amount of soap a little.does not matter if it is liquid or powder.
once every three months you need to run cleaner through the machine.
last thing but very important make sure the incoming water temp i no lowe rthan 120 degrees.
Jun 09, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
We see white all over the spoons and the bowls and not sparkilig white.
Make sure the water is 120 degrees at start up and also that the jet dry dispenser has jet dry. This aids in the clean rinse and spotting on dishes during wash, but most importaant is the water temp. Must be 120 at start up or you get an almost totally cold water wash.
May 31, 2010 | Kenmore Dishwashers
The top does not wash and the bottom some what works. no water pressure
First thing to check is your in coming water pressure and temp.The internal water temp has to be at least 120 degrees to properly clean the dishes.
Second after the machine has stopped filling with water open the door and look at the water level in side you should have 1/2" to 1" of water and it should be hot.
Third if there is not that much water add a few cup fulls off water unit the whole bottom of dishwasher is covered in water. Then start your machine and let it go through a cycle.
If your unit cleans the dishes then you may need to replace the water fill valve,if it does not clean the dishes and the results are the same you need to replace your main wash motor.Remember water temp has to be 120 degrees.
I hope this helps with your dishwasher and you get it fixed fast.
Feb 06, 2010 | Dishwashers
Our Whirlpool KUDP01ILBS2 dishwasher isn't working like it used to. Dishes seem to be getting partially clean, they aren't getting dry at all and it seems they may be being rinsed/washed with dirty...
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Feb 10, 2009 | Dishwashers
Dishes not being washed clean in dishwasher
check your water temp it has to be at least 125 degrees if it aint that then check your water heater
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag Quiet Servies 100
make sure your getting at least 120 degrees in water.Check the heater element,rinse aid ,clogged up spray arms.These are the most common and need to be 100% ok.
Jun 02, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes not clean
Is water temperature at least 120 degrees?Rinse aid must not be empty.Heater is operating
May 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher - water softener not working
Make sure your water temperature is at least 120 degrees .Make sure your heater element is working and last of all ,Rinse Aid is the 2nd most important after water temp.
May 26, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Not drying
These dishwashers have no heater for drying dishes. It has a fan to circulate warm air. It is very important that your water temp is at least 120 degrees. It is the combination of hot water and air circulating that dries dishes.
Nov 19, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
75 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
