Question about Braun Flex XP II 5790 Electric Shaver
Non cleaning razor
My husband has a Braun 5790 self cleaning razor which does not clean.
The clean cycle makes the noises, lights go on but the beard residue stays in the upper tray and no fluid is released to clean the razor. The hole from the tray is blocked by a clear plastic piece and the "spout" next to it goes nowhere either. Is it incorrectly assembled? On reading the instructions I find there is no special cleaning manual that is mentioned in the general pamphlet. Where can I (a) find out how to clean this other than manually and (b) where can I get a cleaning manual?
  • Sharon Ziesnitz May 28, 2008
    Thank you for trying but it is not the fluid container itself that is faulty but rather the actual stand for the razor. I have talked with Braun (Proctor & Gambel) since posting the help request and they agree the stand was not assembled correctly, so I am returning the razor to them for correction or replacement.
    Freddofrog.
Dear Freddofrog,
please ensure you have removed the plastic plugs from the cleaning fluid container. If you have removed these i would suggest that the fluid contaner is faulty, your place of purchase should exchange this for you with no problem.
Posted on May 28, 2008
Braun series 7 cleaning station has red lights even after I replaced the cleaning solution
When the razor is not regularly cleaned in the cleaning station and the hygiene indicator goes low, the cleaning station may lose its ability to sense the fluid level. I almost sent the cleaning station in for repair (mine is out of warranty) but was able to clear the faulty condition by resetting the razor's cutter replacement (holding the small recessed reset button below "Braun" logo on the razor) and unplugging/replugging the station then attempting a cleaning until it performed one completely successful cleaning cycle. After that the fluid level showed full. I also heard that the drain hole in the "cup" where the razor sits can get clogged - not sure what happens then but you want to keep that clean.
Update 2/2018: If you mix your own formula as others note, it is important to include some tap water for electrical conductivity for the fluid sensor to work.
Sep 15, 2013 | Braun 8585 Electric Shaver
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
I have a Braun 760 razor. The two electric contacts on the charging/cleaning base no longer make good contact with the razor. One of them seems to have some corrosion on it and prevents the razor from...
Useaa good emery paper to clean the surface of the contact, use a good contact oil to rub off the rust or dirt in the section. now repeat till it shine, do the same to the other end , Now since there is alwyas some moisture present the pins must be cleaned out after very use.
Sep 28, 2010 | Braun Series 7 9585 Hair Trimmer
I have the Braun 360° Complete 8985 Electric Shaver, and ive learned that it is pritty much gonna keep being a money hole. Can any one suggest a self cleaning brand that is more reliable?
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
http://shaveroutlet.com/shavers/foil-shavers/braun-series-3-370-men-s-shaver.html
http://shaveroutlet.com/shavers/foil-shavers/braun-1775-series-1-shaver-p-123.html
Sep 07, 2010 | Braun 360° Complete 8985 Electric Shaver
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
Oct 29, 2009 | Braun 360° Complete 8985 Electric Shaver
Base floods with solution during cleaning cycle
OK, Remove shaver from cleaning base. Raise top cover as if you are going to replace the cleaning cartridge. Now, look into the cleaning cup where you put the shaver into.You will notice a small hole on the bottom left side. With a Q-tip ,clean out the beard hair from the hole.If you have a model 5301 which is located on the bottom of the base, you should be able to push the Q-tip all the way through the hole. This will allow the liquid to flow back down into the cartridge.This is whats causing the overflow.
Nov 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Clean Cycle Never Ends
i have the same issue but the charge/clean light on the razor itself wont come on or charge at all. Braun said to send it in for repair/exchange and to find out whats wrong with it.
Mar 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Braun Flex XP II 5790 Electric Shaver Logo
322 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
