Question about Kenmore Washing Machines
My Kenmore Elite washer , type 111, will not spin during the spin cycle on any setting.
dididsaythat
  • 291 Answers
SOURCE: kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Posted on Sep 07, 2007
SOURCE: kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Posted on Apr 26, 2009
GodBlessU
  • 3513 Answers
SOURCE: 22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Posted on Aug 30, 2009
  • 311 Answers
SOURCE: My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Posted on Jan 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
177 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
