Astra (ASTRAPRO) Espresso Machine Logo
Posted on Oct 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is coming out of the vacumn valve, changed valve, new one has nice plastic seat. the tank is filling to the top, removed and cleaned high low level probe. Probe is not grounded to probe fitting ie case. water valve is not closing. is there a way to test system or valve? and has water valve failed? machine works well otherwise if you can stand the waterfall off the counter. thank you
Ernest R
Level 3:
  • Master 1,618 Answers
  • Posted on Oct 04, 2010
Ernest R
Master
Level 3:
Answers
1618
Questions
0
Helped
730715
Points
3103
Sounds like the inlet valve solenoid is leaking or something is stuck in the valve plunger.
How do I fix a toilet
Your best bet is to get a new Fluidmaster fill valve assembly at the hardware store and follow the instructions in the package. While you're at it, you will probably want to get a new toilet connector hose (just so you will have nice new gaskets that won't leak) and a new flapper (flush) valve for inside the tank. The flapper valve seats into a round, plastic valve seat that sometimes gets all junked up with calcium so that it doesn't seal well, allowing water to leak down the drain and causing the fill valve to let more water in periodically. You should clean off the surface of the valve seat so it is nice and smooth. I use my hands and a rag for this because I don't want to gouge the surface with metal tools, damaging it.
tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 • Plumbing
    Fluidmaster instructions
    Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
    Aug 23, 2014 • Home
    Water is not coming out on the top of the fill tube that connects to the overflow tube
    It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
    Toilet loosing water in tank. Makes little hissing noise.
    the little hissing noise is probably the valve slowly filling the tank back up and the water leaking out is probably because the flapper ball needs replaced. You can see it and get to it and replace it very easily, it is the black ball in the bottom of the tank, it has a chain going from it to the flush handle.
    First make sure the chain has not flipped over the handle or gotten twisted, I have seen this happen and it does not allow the flapper ball to go all the way down and seat.
    If you rub you finger across the top of the flapper ball and black (deteriorated rubber) comes off then replace the flapper ball, remove the clip from the handle, lift the fubber ears of the flapper ball off of the plastic posts at the base of the bowl fill tube, and replace making sure that there is not to much slack in the new chain, just adjust the clip on the new chain where there is just enough so that the new ball seats.
    Make sure you turn the water off to the toilet before you replace the flapper ball your valve in the tank will open to fill the tank and it will run until you get a new flapper in place.
    You can het a new flapper for a few bucks at Lowes, Ace, even Wal-mart
    Mar 13, 2011 • Caroma Home
    2answers
    I installed a new complete Fluidmaster and filled it up with water but when flushing water comes out under the tank not under the toilet though.
    probably needs a "doughnut" tank washer under tank..or try tightening the tank bolt..fluid master comes with a little rubber hose that goes to overflow tube
    3helpful
    2answers
    Toilet keeps running water in back tank keeps running over top of drain hole
    You don't have to replace, You just need to adjust the fill valve. If you have the ball **** type just tight the top phillips screw. If you have the newer type, close the water valve under the tank and Push down a plastic ring at the bottom of the filling valve, Push down the top of the valve, lift the plastic ring to it's place and open the water valve.
    Aug 01, 2010 • Toto Home
    2helpful
    2answers
    Toilet tank looses water over time
    As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
    Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
    If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
    6helpful
    2answers
    New water valve makes ahigh pitched whistling
    I had exactly the same problem. Just turn down the water pressure @ the valve on the water inlet line. While you have the toilet lid off, you may want to remove the fill valve (1/2 turn counterclockwise on the plastic nut attached to the water-in line), and clean the rubber diaphrams (there are 2). They will sometimes get gritty and this will cause some fill noises and leaking.
    62helpful
    4answers
    Toilet won't stop running
    I have a Kohler toilet and Ingenium fill valve 85297-AA. My toilet kept running, the fill valve black cylinder wouldn't pop up and when I added blue food coloring to the tank, the blue color seeped through to the toilet bowl. First I replaced the flapper and that allowed the fill valve piece on the cylinder to pop up correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had filled and no water was going into the overflow tube. I called the tech support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) . Here's what solved the problem: Turn off the water to the toilet.Take off the white cap of the fill valve by pushing it down and turning it counterclockwise as you would open up a childproof pill container. Then unhook the metal hook. Hold a cup upside down (I used a strong plastic cup) over the part of the fill valve that is left in the tank and turn on the water. (You need the cup because otherwise the water will squirt up to the ceiling.) The water will flush out the fill valve. Replace the cap and the hook and flush.
    Nov 28, 2008 • Home
    Top Astra Coffee Makers & Espresso Machines Experts
    Mike Cairns
    Mike Cairns
    Sulejman Sulejmani
    Sulejman Sulejmani
    Kolbrun...
    Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
