Question about Singer 7422
I have a singer 7422. I am trying to wind the bobbin. It should be the easiest part and last time it was. Now when I turn it on nothing happens. I have the manual in front of me and have checked and rechecked that I"m doing everything it says. I can't figure it out. Machine is only a few months old and only been used a few times. Cheers Sam
To clarify, take the thread from the spool, through that little clip, loop it around the little metal button piece at the top (should have a diagram on top of the machine), then through one of the tiny holes in the upper side of a bobbin. Place the bobbin on the vertical bobbin winder pin/rod on top of the machine then be sure to snap that pin/rod all the way to the right to engage motor. Then try. Most of the time people forget to push the bobbin winder pin/rod to the right which leaves the machine in sewing mode rather than in bobbin winding mode. Easy mistake. ;)
Posted on Jun 14, 2008
Why won't my bobbin winder work
It could be the belt has snapped, or something else it out of adjustment. You can either get it fixed, or purchased an inexpensive bobbin winder for under $25 from WalMart online.
Oct 18, 2014 | Singer Advance 7422 Electronic Sewing...
The center of the hand wheel looks like it should be able to be pressed inward to lock needle while winding bobbin; won't budge but will spin...
Rae,
If you are trying to wind a bobbin or resume sewing, the center knob across many models of machines; is to TURN the center hub to lock or unlock the needle bar sewing action so you can wind a bobbin; or resume sewing.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Jun 15, 2014 | Singer 7422
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Cleaned machine - now can't turn wheel
Check to see if the bobbin winder on the top of the machine is over next to the handwheel, as it would be if you were winding thread onto an empty bobbin. The bobbin in the machine does not go up and down while you "fill" a bobbin.
Dec 07, 2013 | Singer 7422
My bobbin is winding all at the bottom
Did it get put in bobbin winding mode, some how?
Dec 12, 2012 | Singer 7422
Sewing machine Singer Advance 7422, I try to fill a bobbin on the top of my machine. I put the bobbin in position and the shaft will not turn. The machine is treaded correctly and put in the right...
some machine, you have to push the bobbin winder spindle to the
right so that it will wind the bobbin, I have to on mine.
but if you've already done that then the machine needs to be checked
to see what wrong with the bobbin winder spindle
Aug 21, 2012 | Singer 7422
Won't wind bobbin
they have a free manual at singer pdf download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 7422) & click search
Jun 08, 2012 | Singer 7422
Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Nov 10, 2008 | Singer 7422
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Problem winding the bobbin movement of needle doesnt disengaged , then all lights light up as if its a warning after one winding a maximum of two times. singer 7422
Check the buttonhole switch ,if not there there is a microswitch on the bobbin winder that may be out of adjustment
Oct 24, 2008 | Singer 7422
Singer 7422 Logo
191 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
