Question about Danze Fairmont Double Handle Roman Tub Faucet with Valve and Lever Handles
Danze Roman Tub faucet w/shower diverter - D302755\r\nZero water flow from faucet - seems either there is a vacumn breaker issue, or the faucet has is 'vapor locked'. What can be done?
3 Suggested Answers
SOURCE: Getting into Danze Roman faucet to unscrew it
I don't want to pay for anything.  I didn't realize there was a fee attached until I got to the last part so I just shut my computer down without selecting a payment and still you contacted me.  No thanks!  Remove me.
Posted on Jun 23, 2009
SOURCE: danze sonora roman tub personal shower stopped
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Posted on Jul 14, 2009
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
The water comes out of both the shower head and the tab simultaneously. If the knob controlling the water flow is turned to the side that control the water to shower head then about 75% of the water flows...
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Jun 02, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
I need an adapter for a roman tub filler the aerator is about an inch and one sixteenth round with fine threads i would like to install a diverter for a handshower thanks
c51b8b5.jpgPersonal Shower Adapter Fitting
Remove the aerator from the spout and take it with you to your local hardware store or home center (for sizing purposes). These are usually sold with an aerator thread adapter, which allows it to connect to most faucets in the marketplace.
Feb 06, 2010 | Danze Fairmont Double Handle Roman Tub...
Water coming from faucet and showere head when the
the washer on back of the dirverter knob needs replacing or the seat behind the vavle stem
Aug 18, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Danze sonora roman tub personal shower stopped spraying, no kink in hose, no plug in sprayer
Jun 27, 2009 | Danze D303754CSN Sonora Roman Tub Faucet...
Jun 22, 2009 | Danze Home
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Danze Fairmont Double Handle Roman Tub Faucet with Valve and Lever Handles Logo
132 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
