Question about Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
  • thomas Apr 24, 2013
    Did you ever get this solved? I have the same problem.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Xerox Expert
  • 142 Answers
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Posted on Mar 08, 2015
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
  • 49 Answers
SOURCE: Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Posted on Mar 31, 2009
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8560MFP/N System error
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Posted on Jul 31, 2009
  • 526 Answers
SOURCE: XEROX Phaser 8560MFP won't go past "initializing?"
Disconnect the data cable between the Electronics Module and the Printhead to see if Power On Self Test (POST) gets further, to the point where it displays a system failure code relating to the Printhead being disconnected. If so, replace defective printhead.
Posted on Dec 13, 2009
darkpain
  • 316 Answers
SOURCE: xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Posted on Feb 04, 2010
Phaser 8560 wont print
I've had my HP do this a lot with my Probook. Sometimes I have to turn my printer on manually even though the light is on, it sometimes go into a sleep mode. Maybe your printer does the same.
Also, have you made the printer your "defaul" through control panel settings? Just a few ideas.
Feb 11, 2013 | Xerox Phaser 8560MFP Laser Printer
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
May 20, 2011 | Xerox Phaser 8560MFP Laser Printer
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
Wont copy, displays 09,038,46: 14444
www.support.xerox.com/go/results.asp?...8560MFP...
This is a fault of the inkloader. A broken ink is not tripping the sensor, or it is out of ink.
Turn on printer. When logo starts, press and hold the info and back buttons until it says entering diags.
Go to functions menu, scroll to reset IRC counter,enter, and then exit diags. Printer will boot to ready.
Well when the logo is moving before it centers is when you hold down the back and help buttons and it should reboot in service mode, usually it takes it a second or two to start the process. So you can try that again or go into service mode the way you did before. Once in the service/diagnostic mode you need to scroll to the bottom to the function menu then reset the IRC counter in the sub menu and you should be good to go. You were almost there before. I have to do one today so if I notice anything different than the instructions given to you I will post back but Ive done it several times and everything sounds right.
Master link below. http://webcache.googleusercontent.com/search?q=cache:RP4PhFss0oMJ:www.fixyourownprinter.com/forums/printer/62877+Xerox+Phaser+8560MFP/D+error+09,038,46:+14444&cd=5&hl=en&ct=clnk&gl=nz
Jun 10, 2010 | Xerox Phaser 8560MFP Laser Printer
I own a phaser-8550 and the problem is that the printer seems to wake up when it is in sleep mode. If I turn it off and back on the next day, jobs print OK until it goes to sleep and it forgets to wake up....
There are two stages to the sleep mode, One is a low power condition. That is the real sleep mode. There is also a time that will shut the machine off. You can go into the machine setups and shut that timer off.
Mar 09, 2010 | Xerox Phaser 8550/SDT Color Laser Printer
Phaser 8560mfp system error 09,038.46:12367
Solution:
  • Turn off the printer. Turn on the printer.
  • As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
  • Release the buttons, it will now come up in the service mode.
  • Scroll down to the function menu, hit ok, scroll to clear isc fault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Oct 16, 2009 | Xerox Phaserâ„¢ 8560MFP/D All-In-One Laser...
Xerox 8560 is very hot even in sleep mode
the fusers get about 300 degrees to melt the toner to the page. If you do not have the phaser clean regularly, the paper dust that is next to the fuser could smell like it is burning.
Jul 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Error 09,036.44:41689
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
May 01, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 outputs Cleaning Pages several times a week. The unit is never turned off and only goes into "sleep" mode. Last time it woke up at 1:00 AM and went through the noisy cycle and output the...
There is nothing you can do about the cleaning page. And if its only using 20% of your ink, you're luck normally its 25% of the ink. This is simply how the machine works. Nothing can be done. The Xerox employee was simply trying to give you something to try, but it won't change anything!
Mar 27, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
312 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
