Question about Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Red light on display not green as usual
Did you solve this issue and how?
    Problem Solver:
  • 6 Answers
Hold down the "input" button and "volume -" button while the MAIN POWER BUTTON IS OFF. Then turn on the main power button while those are held down, the light on the tv & avc box will turn green. When it turns green, immediately let off the 2 buttons and press "volume +" button, then press the "Main Power" button. Next step is to repeat the process about 20-40 times & the TV WILL WORK!. I have read that this may have something to do with the energy star compliant commands that can changed through the serial port.
The above is from psxpirate25. Thanks!
I had to repeat the whole process a couple of times to get rid of the factory setup firmware mode. Do it 40 times, I would mess up the sequence a couple of times. Keep trying, it does work.
Posted on Aug 13, 2008
  • AirmanB29 Aug 14, 2008
    Well, that was last night. Tonight it is doing the same thing, except it won't respond to the power button sequence. Do not know what to try now. Seems like it is the control box that is flaky.
Lcd is onbut no picture display red light is continue is on solve my problem
if the red light is on then there is no input from the computer as the red lights would go green or blue
take it to a computer shop and have it checked out a sit could be the hard drive or graphics board
Feb 21, 2016 | Computers & Internet
The red protect light comes on, i dont know how to make it go green so it will work. please help!!
Devices with several light emitting indicators would each display as observation of manufacturers installed features. Red indication is power cciuit indication, yelow as alternate warning where green is indication of regular fucntionality. Once the device is least malfunct, every light is an equal expectation. Usually with amplifeiers, the red light has to be on throughout until stereo became powered on to porduce green light effects as radio expectations.
Feb 14, 2011 | Volfenhag ZX-8200 Car Audio Amplifier
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
I bought a MTX Terminator amp and the light is red when I turn it on, but it works. Red usually means protect mode but it works fine. Should the light be red or green?
all depends on that amp... if there was an issue it wouldnt work, and the light would be by a protect symbol... if its just red next to the power symbol i say no issue.
Feb 18, 2010 | Car Audio & Video
I have a red stripe across the top off my tv
This issue is because of a defect in the light engine. The only way to solve is to replace the whole light engine. They usually run anywhere from $500-$2500 depending on the model. Sony extended the warranties for the light engine on certain models that have this problem because of the defect, contact Sony to see if a certain TV had the warranty extended.
Oct 05, 2009 | Sony Televison & Video
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Charging indicator stays red
Hmmm...is the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Oct 16, 2008 | HP iPAQ hw6965 Smartphone
Sharp Aquos LC-37HV4U 37 in.  LCD HDTV Logo
160 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
