Question about MSI AIO AE1900-01SUS 18.5-Inch Touch Screen Desktop PC
Hello, my touch screen acting crazy …. A calibrate it with success, but when I go back to main screen and touch any icon on desktop the touch is on opposite side like 2” from original touch, also when I plug usb keyboard it does not work. Everything have been working great last week. I have MSI 1900. Thanks
  • Mirek1 Oct 03, 2010
    when I calibrate the screen all 9 touch points work fine...... I believe there is some issue between softwares..... touch screen and mouse or touch screen and keyboard....
    Hello, my touch screen acting crazy ?. A calibrate it with success, but when I go back to main screen and touch any icon on desktop the touch is on opposite side like 2? from original touch, also when I plug usb keyboard it does not work. Everything have been working great last week.
    I have MSI 1900.
    Thanks
  • 857 Answers
I just read all your logs, after reading the logs what i can suggest you is to get it repaired in the service center becuase even if you try a software update if the screen id not working u wont be able to do anything.
Get it serviced thats the only solution.
Posted on Oct 03, 2010
  • 182 Answers
Even after calibrating if the issue remains the same this is a clear indication that there is a problem with the touch screen it self.
In order to fix this problem you need to take it a service center because there is a problem in the mainboard from where the touch functionality comes from.
However if you want to try on your own,
you may open it use a hair dryer to remove moisture and then reset the unit and check if it helps. If it doesn't please contact the manufacturer for help.
Touch problem
Nokia designed the N97 with a touch-screen calibration program to remedy problems with the touch screen. Opening the touch-screen calibration program requires you to use the touch screen, which can prove difficult. You're forced to judge where to tap the screen because the screen isn't recording the precise location of your taps. To find the touch-screen calibration program, open the main menu, select "Settings" and then "Touch Input." The program provides on-screen instructions to help you finish calibrating the screen.
Oct 23, 2012 | Nokia N97 Cell Phone
Touch crosshair to calibrate is on my screen how do I get back to main menu screen?
my android saying touch crosshair to calibrate try once more how i can get back my main menu please
Mar 04, 2012 | Coby Tablets & eReaders
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
My touchscreen is acting crazy. Think it need calibration. But how do i do it if the screens acting crazy. please help.
i know some people that have had that problem and they fixed it by taking the battery out and putting it back in, when they restarted it it worked fine again after calibration.
Aug 09, 2010 | LG KU990 Viewty
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
Nintendo DS touch screen not working properly
Turn the ds on without a game in it and go to the settings icon (looks like a tiny ds) on the bottom middle of the screen then go to the far right yellow icon and it will re-calibrate the touch screen and let you know if calibration was a success.
Jan 11, 2009 | Nintendo DS Console
MSI AIO AE1900-01SUS 18.5-Inch Touch Screen Desktop PC  Logo
313 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
