Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishes not clean
Soap not disolving dishes not clean
  • 1 more comment
  • curlytopDad May 27, 2008
    yes the temp is120 degrees rinse aid is full heater is operating
  • Anonymous Dec 10, 2008
    yes, there is food in cups and it is not cleaning well
  • pbentha Jan 02, 2009
    Maytag DWU8860BAE. We keep finding parts of our detergent bars in the machine and the dishes aren't really clean any more. The spray holes are all free of debris and the rinse aid is full. The temp boost is "on", the rinse temp is set to "sani", and the fan dry is set to "heat".
  • 868 Answers
Is water temperature at least 120 degrees?Rinse aid must not be empty.Heater is operating
Posted on May 27, 2008
markevans
  • 148 Answers
SOURCE: Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Posted on Dec 28, 2007
SOURCE: saop not disolving
Great...but HOW do you check the pump screen??? Where is it? How do we get to it? Without this information...these solutions are useless.
Please help.
Posted on Aug 02, 2008
  • 228 Answers
SOURCE: soap dispenser is not releasing
if you are using tablets as opposed to liquid then just put them in cutlery basket at beginning of cycle wash result will still be the same, probably wax valve has failed these do go often and will need new dispenser or wax valve service engineer will need to change
Posted on Nov 10, 2009
  • 677 Answers
SOURCE: soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Posted on Jan 20, 2010
  • 244 Answers
SOURCE: i have a ge quietpower 3 dishwasher. Lately it
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Posted on Jun 10, 2011
My Frididaire Dishwasher Model FDB1250REC1 is discolored inside. Its a browninsh color and it has gotten on my Corningware dishes and stained some of them. I can get most of the color off the dishes if I...
so you need to install a water filter, before you connect water supplie, then you need a special soap to clean wachine (Calgonit diswasher cleaner powder ) use-it without dishes. then use a dishwasher salt (to disolve all water dirt and colour) and rinse liquid (to give a clean glass dimond finish ).
use Calgonit Brand is the most trush, on the masket
Feb 14, 2010 | Dishwashers
Soap does not disolve and residue left on all
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Residue on dishes, soap not disolving. tried jet
Check the water intake screen for sediment. Often if enough sediment builds up the screen becomes clogged and these symptoms present themselves.
if you send me the make/model I will tell you where the intake screen is. Probably you have to take the unit out of the cabinetry and turn it over as most of the time the intake valve is inconveniently located on the bottom of the unit.
Oct 11, 2009 | Kenmore Dishwashers
Soap does not disolve (licquid or pouches(. just
Make sure your spray arms are not clogged, large untensils/ pans hitting spray arm(s)??
Is the d/w filling with the proper amount of water?
If the above is ok, then you might have a clogged sump filter or weak main wash pump
Apr 29, 2009 | Dishwashers
Whirlpool gold builtin dishwasher
Do not recommend premeasured tablets, usually too much soap. If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and make the soil sensor think the dishes are real dirty initiating additional wash cycles. Use rinse-aid for better drying performance
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish soap not disolving
Is the water heating up? This may be the problem.
Apr 14, 2008 | Dishwashers
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Nov 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
94 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
