Question about Canon PIXMA MP160 All-In-One InkJet Printer
"The ink absorber is almost full. Press printer's Start button to continue printing. Contact the service center." What does this mean?
  • Canon Master
  • 5,343 Answers
This means that the counter related to the amount of ink these pads absorb during print head cleaning cycles and from edge to edge printing is nearly at the programmed limit. You can still print by pressing the Start button.
However, you can expect the printer to stop working soon. You can clean out the waste ink pads yourself. This is a bit messy so have plenty of newspaper around. Disassemble the printer from the top. The pads (rubber of some type) are below the cartridge carrier on the side. Pull them out and blot most of the ink off them. Then run under water until the water comes out clear. Allow to dry (you can speed up the drying process with a hair dryer).
Finally reset the waste ink counter in the service mode:
With the printer off but connected to power, Press and hold Set/Reset and then press the Power button. When the power light is lit, continue to hold the Power button and press Set/Reset twice. The light should be green.
Now press Set/Reset 4 times (the light will switch between orange and green at each press). Turn off the printer. The counter should be reset.
Do not reset the counter without cleaning or replacing the pads. You will get ink spreading all over the printer. Additionally, the waste ink counter is set to a value that should be reached near the printer's end of life with normal usage. Other parts may fail soon.
I hope this helps.
Posted on Oct 03, 2010
    New Friend:
The ink absorber is almost full. press the printer's RESUME button to continue printing, contact the service center.
Posted on Dec 29, 2012
  • Rubel Dec 29, 2012
    the ink absorber is almost full. press the printer's RESUME button to continue printing, contact the service center.
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer won't print. Says to contact service
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
The ink absorber is under the print engine and covers the whole bottom of the machine. It is 5 inches wide and over a foot long. Did you really clean this part? You can't reset the error code without getting into the diagnostic program which only a shop can do...
Jun 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Try this:
Thanks, Joe
May 01, 2009 | Canon PIXMA iP6310D InkJet Photo Printer
Canon MP145 Ink Absorber Full Problem.
I got on error message when started to print.
It’s kept happened and message dialog box “The ink absorber is full” occurred.
Mine is Canon MP145.
Can somebody please help me , on how to fix this problem !
tq
Jan 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
882 people viewed this question
old marine
old marine
