Question about Dryers
I have a GEQ8811PW0 whirlpool dryer that will not heat up. I have followed most of the steps to determine that the heating element and thermal cutoff components are functional using a multimeter. I am not 100% sure that I am using the multimeter correctly. It is a fairly inexpensive model. I set it to OHMS using the setting that looks like a sound wave and it gets a reading when connecting to both ends of the thermal fuse, operating and high limit thermostats. Basically it just has a constant whistle sound. From this I assume that it means these are ok. I am now suspecting the timer or somthing else is gone bad. Please help, Thanks Aaron
  • aaron_phi744 Oct 03, 2010
    **** I think I just got it. It seems the power outlet is messed up so that the connector on the right wasnt connecting fully. I unplugged it then bent it slightly and pluged it back it hoping for more contact and it worked
    President:
  • 1,554 Answers
Better replace the power cord/plug to avoid further damage to the outlet. Loose contacts can result in electrical noise interference with the rest of appliances in the house or the dryer itself.
Posted on Oct 04, 2010
  • 10,865 Answers
Hello Aaron. When a dryer will not heat Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Oct 03, 2010
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
Dryer was heating, the motor running. heating element is not gettin hot but we have power.
CHECK YOUR BREAKER BOX FIRST. THEN MOVE ON TO THE DRYER VENT THEN THERMAL CUTOFFS THEN ELEMENT. THAT IS ALL OF YOUR HEATING PARTS. GOOD LUCK RATE ME!
Aug 26, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool Dryer LER5636EQ3 will not heat replaced heating element, jumped out all temp and heat fuses.
Betya missed the thermal cutoff. Located half way up heater canister above the t-stat. This is usually the cause.
Feb 13, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool GEW9200L not heating up, i have replaced th thermal fuse, thermistor, heating element, thermal cutoff and high limit. What next.
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Oct 05, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlepool dryer Ultimate care2
Have you checked the heating element? Also, your dryer vent may be clogged with lint.
Aug 24, 2009 | Whirlpool LER4634J Electric Dryer
No heat
If this is a GAS dryer make sure that the igniter or pilot light has not gone out. If this is an electric dryer, check the vent to make sure it has not clogged up and prevents the air from circulating in the dryer.
Otherwise if it is an electric dryer, make sure the heating element has not blown a fuse or burnt out.
Feb 19, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
