DVD/CD ROM will not open on the emachines desktop. I hear it making a loud noise, it still will not open, even after rebooting several times. Not sure how to open it to insert a disk. Help?
Coldcut
  • 1554 Answers
SOURCE: DVD/CD ROM problem (Dimension 5150)
you cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Posted on Jan 26, 2008
amusedgeek
  • 787 Answers
SOURCE: my dvd/cd rom would not
Do you see a tiny little hole in the front of the dvd/cd tray?
Straighten out a paper clip and insert into this hole, a gentle pressure will turn a gear that opens the tray.
Posted on Sep 29, 2008
techniwiz
  • 275 Answers
SOURCE: dvd player won't open
first of all is the system under warrantty?
secondly the paper clip should work in any case
its either u are not applying proper presure or the clip is short ... the clip should be atleast 2 inches long and when u insert the clip at some point u will feel there is no place inside thats the time u apply presure and it should open ... its a way to open the tray which works on mechenical parts so there is no point of failure with them
Posted on Nov 14, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Don't know how to reformat my emachine T5010 desktop PC
Reformatting your Windows computer is usually the absolute last resort and is often done unnecessarily. Before you go through the process of doing a reformat of your hard drive please take a few moments to read through the rest of our website. If you are reformatting to fix problems with your Windows computer it's possible that by using some of the tips on our site, or by downloading or purchasing some of the tools or products that we link to, you might be able to avoid the need to reformat your computer. Because doing a complete reformat of your computer will erase the contents of the hard drive and require you to reinstall all software, reformatting is usually a last resort. Some Computer Manufacturers Make Reformatting EasyMany name-brand PC manufacturers include a restore-disk which makes it easy to reformat your PC and return it to the state it was in on the day you purchased it. Some manufactures supply only a standard Microsoft Windows CD, and some (usually lower-end PC manufacturers) supply neither! If your PC did not come with a restore or reformatting CD, then you will need to take extra steps to format your hard drive and get Windows re-installed. Back Up Your Files Before You Reformat Your Windows PC!Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
Things to do before you reformat your PC hard drive
  • Write down or print out all notes and internet pages because once the format process begins, you will no longer have access to them (or anything else in the PC)
  • As already stated, BACKUP all important files and data! When you reformat your computer everything will be erased!
  • Make sure you have all the CDs and other software. All programs will have to be reinstalled after you format the hard drive. Don't forget about software that came with hardware such as printers, scanners, etc.
  • Write down the brand and information for all the hardware on your computer. Look in the Device Manager and make note of the brand and model of network adaptors, video cards, sound cards, printers, modems, and displays. After reformatting you might need this information to reinstall drivers.
Posted on Nov 15, 2008
  • 66 Answers
SOURCE: JLMS DVD-ROM XJ-HD166 cannot detect any CD
dear friend this is due to u are using a pirated cd .
or your computer lens is not able to read it .
so no need to worry if you have problem try other cd .
and if it fails please contact me
Posted on Mar 28, 2009
Dvd burner wouldn't close session - won't eject - now computer not acknowledging disk in cd-rom and it won't manually open. Rebooted several times. Rebooting taking longer now.
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
if your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver
hope this helps
Apr 28, 2011 | E-Machines emachines (emachinees) CD-ROM...
My cd/dvd rom stopped working... you can hear it running for a min. or so then nothing... it wil not download my photos from my camera either... I Have a T3985 Emachine desk top ( DVD+/-RW )
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 09, 2011 | E-Machines emachines (emachinees) CD-ROM...
Can you play PC DVD ROM on an emachines E4026 Desktop PC. because i just had a game brought for me & when i try to load it , the computer reads it as a blank disc Any help appreciated ...
Based on the one and only specs sheet I could find for this model of emachine, it does have a DVD-ROM drive. So in theory it can. Does the unit play DVD Movies? if yes then it should work, try rebooting and then putting the disc in again. I assume the disc is clean and scratch free as the game is new.
If the OS on your computer has ever been reinstalled, you may be missing the driver for the drive, in which case windows would treat it as a generic CD-ROM drive, and not be able to read DVDs, you can get the drivers for the drive from the emachines website if this is the case.
Dec 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
Emachine T4060 -black screen-no cd-rom boot
If it is DVD Drive, then sometimes in BIOS you'll also find the option for DVD Drive together with CD Drive. Choose the correct one and boot your PC.
Please come back and vote for me, if this turns to be helpful for you. Thnx
Mar 27, 2010 | E-Machines T4060 PC Desktop
Need to replace dvd/cd drive for emachine desktop,
just u replace try with ASUS dvd/cd drive it will support you
Jul 03, 2009 | E-Machines emachines (emachinees) CD-ROM...
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
My dvd/cd rom is not opening, checked hardware, not even listed
just check your dvd writer is open or not open because the some time not open the dvd driver then not detect
fist of all remove the dvd rom and reinstall because the some time remove the dvd drive and after reboot the laptop and check ..............ok
Apr 08, 2009 | Computers & Internet
CD and DVD drives
cd rom drives are pretty straightforward. if they dont open, there's no way to fix it since the units are non user serviceable. replacement is the only option. :)
Oct 14, 2008 | E-Machines eMachines Desktop PC
Cd/dvd
Try deleting it from the Device Manager and rebooting. If Windows has eaten the driver, it will try to reinstall it during the reboot.
Follow this sequence:
- Start
- Control Panel
- System
- Hardware
- Device Manager
Locate the entry for DVD/CD-ROM Drives and expand the listing.
Highlight the drive(s) and delete them.
If the Plug & 'Pray' is working, Windows will 'find' a new device and install the basic drivers for it.
Aug 31, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
