Question about Denon AVR-1706 Receiver
I don't have any sound when I turn on the Denon DVD player. I have checked the back of both the receiver and the dvd player and there are not any wires off. As far as I can tell all the wires are in the right place.
    President:
  • Denon Master
  • 1,114 Answers
Check the "Input mode" on the receiver for DVD input. Make sure the input mode is set to "Auto" if you still have a problem, post a reply and I can help you further
Posted on Oct 04, 2010
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
Denon AVR-1906
it is receiver defect only i think
Jun 04, 2008 | Denon AVR-1906 Receiver
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Denon AVR-1403 connected to DVD can hear music but no dialougue!!
Check the center channel speaker and the surround sound audio settings. If you do not have a center speaker, it needs to be set to off on the receiver.
Jan 19, 2009 | Denon AVR-1403 Receiver
Everything was working fine, tonight i turned on my denon and i no longer have a picture on tv1 if i change the source to dvd i have a picture but no sound. i am trying to watch tv through my dvd player....
First, check if all your cables are still properly connected, specially when it was working fine, this seems to be the most logical explanation. Otherwise set the Denon back to factory settings and see if that helps.
Jul 08, 2008 | Denon Audio Players & Recorders
No Audio coming from DVD source
Press the input select button on front of receiver until auto is displayed it may be set for analog. Auto mode will play digital signal first then if it does not see a digital input it will check for analog signal. I would set it to auto for all inputs you may use.
Jan 10, 2008 | Denon AVR588 Receiver
Poping in speakers
Same issue with my AVR-589...2-15 minutes after sound is playing (via TV or DVD). I checked all wires and speakers. Even reconfigured to audio only (analog) coming in, same issue. Put my old Denon receiver in and the problem disappears...possible overheating issue with this new unit?
Dec 22, 2007 | Denon AVR-3806 Receiver
Denon AVR-1706 Receiver Logo
117 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
