Question about LG DLE2512W Electric Dryer
Dryer makes a rumbling sound while running. Like a bearing or spindle going bad
  • 489 Answers
Possible problem with one of the roller guides supporting the drum. You will need someone to come out and disassemble the unit to see what the noise is. Have them check the 4 roller guides and the motor for any problems.
Posted on Oct 04, 2010
Fisher & Paykel smartload dryer LOUD rumbling sound
post a vid on youtube and ask the question again with a link
to the vid
cheers
Oct 30, 2016 | Fisher Dryers
2001 Ford windstar has a rumble/vibration on left front when driving over speeds of 10 mph. Consstant and increases with speed.
It sounds like you have a bad spindle/hub. You will need to jack up the front left tire, remove the wheel and the brake caliper and pads. Now spin the hub by hand. If you hear a grinding like sounds or low rumble sound, or there is more resistance than normal, replace your hub/spindle assembly.
Jul 06, 2011 | 2001 Ford Windstar
When I engage the mower blades it makes a nasty noise, like a bad bearing. I checked the brakes, belts, etc and all is well. Any thoughts?
hi there mrswp211
check out the pulleys from the pto to the deck for noise - if rumbly / noisy replace them , if not
remove pto to deck belt ( make note of belt routing 1st ) then rotate blades and spindles by hand give a good spin you should hear if noisy , grab blades and try to move them fore/ aft to see have movement if they do and they are not smooth and quite spindle bearings are the problem
generally if unit is noisy only when deck engaged bearings will cause this
but make sure pulleys on the top of eack spindle good to and everything is tight
a badly slipping vee belt will make a squeeling noise and somtimes will make the unit shudder
you will have to remove deck to replace bearing(s) , from experience replace mandrell/ spindle assys do both at same time because if one has gone the other wont be far behind - both do same milage and work and quite often if replace bearings only they dont go back in tight .
cheers hope it helps
pauly46
May 29, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Dryer is making a very load almost vibrating or rumbling noise when operationg.
It sounds like the bearings on your rear rollers are bad I would need make and model to help you further. If its a maytag its almost definitely your rear rollers. hope this helps. MJ
Apr 14, 2010 | LG Dryers
As the dryer runs there is a very loud rumbling
The drum support roller has wrn out and needs replaced. There are two and both should be replaced at the same time. eric
Aug 10, 2009 | Dryers
MayTag Neptune MDE6800AYW dryer drum making rumbling knocking noise
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Jul 09, 2009 | Maytag Neptune MDE6800 Electric Dryer
Maytag gas dryer
The spindle or shaft turning the drum may be bad. The motor as well could be slowly but surely grinding to a halt.
Jan 25, 2009 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Frigidaire dryer makes noise when it tumbles
"spindle" would seem to refer to the rear drum bearing but teflon would describe the front. Have they both been done? Usually when one is worn out the other isn't far behind. Check the idler arm/wheel for wear. Also motors make a sound when the bearings are bad
Jan 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
LG DLE2512W Electric Dryer Logo
129 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
