Question about HP Pavilion dv9000z Notebook
Ho do i connect my laptop to my flat screen samsung tv
    Scholar:
  • 110 Answers
There are 3 ways ways to do this from the left side of the laptop.
1) S-Video-out jack [Connects an optional S-Video device such as a television, VCR, camcorder, overhead projector, or video capture card.]
2) External monitor port [Connects an external VGA monitor or projector.]
3) HDMI port (select models only) [Connects an optional video or audio device such as a high definition television, set-top box, DVD player, or any compatible digital or audio component.]
Your TV will have one of those interfaces. You just need to look at your user manuals for both the Laptop and TV
Take Care
Posted on Oct 03, 2010
My acer laptop screen has broke and i would like to know if its possible to connect it up to my 42" samsung plasma ?
Most laptops have a 15pin D-sub connection that allows you to attach an external display. Most LCD and plasma TV's also have a 15pin D-sub connector to connect a PC to.
Look on the side of your laptop and the back of your TV for this connector and if both have it just find a standard monitor cable to connect them.
Your laptop will have a function key to enable or disable the external display.
Mar 18, 2013 | Televison & Video
How do I connect my TV with the VCR Flat screen Samsung
here is the manual: http://www.samsung.com/us/support/supportDownloadCenter.do?prd_ia_cd=N0000347&prd_mdl_cd=LS27HUBCB%2FXAA&prd_mdl_name=275T
the TV you are using has to be connected with AV devices and can only be connected to video. You need speakers if you want sound.
May 26, 2011 | Samsung SyncMaster 275T+ 27" Wide Format...
Hi How can i connect my samsung plasma tv to laptop
hi ,
you can cenect your laptop to samsung plasma TV using VGA cable to your laptop.
After all seting up, by pressing combination fn + F5 or F3 depend your laptop you will conected to samsung plasma tv.
plasma will automatically detect your laptop connection. If not detected, you can choose PC input manually by pressing source on remocon.
thanks.
Mar 21, 2011 | Samsung Televison & Video
I wanted to know if there is a way to hook my Samsung N150 Verizon netbook or notebook to my tv to watch a movie from the laptop
If the netbook has an HDMI port, you can connect it to most flat screen tv's with an HDMI cable. If there is no HDMI port, then you cannot connect it to a tv.
Hope this helps!
Regards,
Joe
Jan 02, 2011 | Samsung Computers & Internet
Hi my ho nx9005 laptop screen keeps flickering
you have a problem with your flat it is a cable connecting the monitor to the notebook itself and may be damaged or not fixed in it's place
Oct 26, 2009 | HP Computers & Internet
We are trying to use our Samsun HDTV 1080P as a PC monitor
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Oct 18, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HP Pavilion dv9000z Notebook Logo
570 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
