Question about Epson Stylus CX5400 All-In-One InkJet Printer
When I try to print a picture from GOOGLE on my EPSON STYLUS CX5400the colors do not come out right. The pictures have a reddish tinge to them-not the true colors. I have done aboyt 12 HEAD CLEANINGS and NOZZLE CHECKs over the last two days but the only color that comes up on the NOZZLE CHECK is magenta- the cyan and yellow do not come up. My ink levels are at 60%. Please tell me what else I can do to try to fix this problem. Thank you.
    Brigadier General:
  • 10,406 Answers
You've either got clogged jets, or those two ink-wells are empty.
If running a "cleaning" does not improve anything,
then try replacing the ink-cartridge.
Posted on Oct 03, 2010
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Older Epson stylus photo rx600 printing orange
Cleaning cycle a few times. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 28, 2009 | Epson Stylus 1400 InkJet Photo Printer
MacBook Pro Epson Print Driver Dilemma
your problem is about profiles. The gutenprint is the only way to print from intel to r1800, but this driver don't use the same ICC profiles. You have to use one of three solutions below:
1 the best, you have a profile calibrating device, you make a profile of your couple ink-paper and you convert your document into this ICC profile.
2 you convert your picture into your software in one of the Epson generic profiles (hey probably still are on your computer) and you print whithout color managment
3 (awful) you anticipate the color distorsion and you tune your picture to be bad on the screen but pretty good on paper.
Feb 03, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
PRINT COLOUR IMAGE FROM GOOGLE IMAGES
getting vertical lines on my pictures . i have a epson cx5000.
Jun 08, 2008 | Epson Stylus C66 Inkjet Printer
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
Feb 09, 2008 | Epson Stylus RX500 All-In-One InkJet...
All pictures printed are blue
Do head cleaning. If your using Windows XP: click on start;control panel;printers and faxes; right click on the stylus photo 1290 icon and then left click on printing preferences.
Go to maintenance tab.Try to do 3 head cleanings. After head cleaning, try to print.If the picture is still bluish; go to printers and faxes; go to printing preferences; click on advanced button.
On the upper right part of the window you should see there color management, click on ICM and turn off, click on apply and ok.
try to print, if it is still the same, try to use another program to print your pictures.
Feb 04, 2008 | Epson Stylus Photo 1290 InkJet Printer
Problem with Printing BLACK AND WHITE picture on Epson Stylus C88
i think theres problem on your printer head ..try to decloge printer using head cleanig on printer properties.. or other option is to removed printer head steam nozzle on hot hot water to easy removed clog make it sure its dry before you install and the last option is to replaced printer head... tnx good day.
Dec 14, 2007 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus R220 Color Problem
Well, that's true you need to have an original ink to achieve the perfect color... but then its too expensive... I use "bottomless ink" search that at Google website to have an idea... so far I have perfect colors.
Oct 20, 2007 | Epson Stylus R220 Photo Printer Color...
Printing
hello,
probably the printer takes his own color-profiles installed by epson.
Click on propriaties of the printer and create your own color-profile for diferent sizes.
you can take the color-profile from a smaler size and save it choosing an other size.
So You also can improove your pictures by changing the color-profile after your needs...
but then you should use the same paper , because different papers give different colors.
you can also improove the colors by choosing-on the profile-another type of paper.
i hope i could help
Oct 16, 2007 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
