Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Only one wired connection works - Belkin (F5D8231-4) Wireless Router (F5D82314)
    President:
  • 2,571 Answers
Have you tried the same cable in all 4 ports?
If it works in all the ports, plug the other cables in and reboot everything. PC,s modem and router.
You may be getting ip address conflict, rebooting should cure it.
If the same cable just works in 1 port, the router is broken
Posted on Oct 03, 2010
The horn my nissan elgrand has stopped working i have checked the fuses they are ok
A bad switch or wire or connection of the wire to the horn. Try to jump a wire from positive termananl to the horn connection. If it
works the horn is ok. the problem is wire, possibly relay or connections. Back track the wire from horn to the next connection
Mar 15, 2015 | Nissan Cars & Trucks
Malibu transformer on but lights dont work
Voltage drop because transformer is not putting out enough power as when it was new.
Or Short along the wire somewhere.
Connect new wire and 1 bulb, but do not connect to existing wire.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Apr 14, 2013 | Hardware & Accessories
What does the two wires from the furnace to OD unit connect to?
measure the voltage on coil of od contactor should be 24 volts
Aug 24, 2012 | Goodman Heating & Cooling
I have a Intermatic Wall Timer Model EJ500 and I only have 3 wires and can I usethe Wood Model #59028 and where can I get one if it works. I had a single pole switch when I installed the Intermatic. The...
Yes you can use 59028 if you have Neutral or bare ground wire.
EJ500 is battery operated.
Woods 59028 uses electricity to power internal electronics. Like plugging in alarm clock so timer mechanism works.
That's why 59028 has white wire and EJ500 does not.
EJ500 can be used for 3-way switching, so it has extra red wire that is capped off in single pole operation. EJ500 blue wire connects to Load (light,fan, motor)
59028 is for single pole only. The red wire connects to Load.
Here's how to wire 59028:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
1) Timer-green-wire connects to bare ground wire.
2) Connect 59028 red wire where EJ500 blue wire was connected.
3) Connect 59208 black wire where EJ500 black wire was connected.
4) When electric box does not have white neutral wires, then connect timer-white to bare ground.
5) Turn on electricity, and push door on 59028 timer to activate on-off override. If Load comes on, timer is wired correctly. If Load does not come on, then reverse timer-red and timer-black wires.
Jan 18, 2011 | Woods Hardware & Accessories
The old timer that was there quit working tryed to put a new woods one in but cant get it to work help
The following wiring diagram works for Woods, GE, Hagar, Leviton, Sylight, Utilitec, some Intermatic in-wall timers.
It does not apply to Aube timers or Intermatic battery-operated timers.
If the wires are not connected correctly, the timer will not operate as expected.
Click the manual override and see what happens.
If the lights do not turn ON with the manual override, then the wiring is suspect.
If the lights blink, then you have put the red and white wires together.
If the lights turn ON, but timer clock is not working, it is possible you have the black and red wires reversed.
If the white wire is not connected correctly, the clock mechanism will not operate.
Review the wiring.
Black-timer wire goes to black-hot-wire from breaker
Red-timer wire goes to black-wire going to Load (lights)
White-timer wire connects to the Neutral wires that are usually twisted together and covered with a wire nut.
IF your box does not contain those white wires, then you can work-around by connecting white wire to bare ground wire.
Nov 02, 2010 | Woods 59028 Programmable Timer Switch...
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
I have a westinghouse ceiling fan model 78622, where do i find a wiring manual for this. I have connected up the fan in place of an old one that was taken down, the wiring seemed straight forward but only...
If you have only a black and white (and bare ground wire) in the ceiling box where the old fan was connected before, you should connect both the blue and black wires from the fan to the Black (common) wire in the ceiling box.
Then connect the white wire from the fan to the white (neutral) wire in the box together. Connect the green and bare wires together (Ground wires) and the fan and light should function with the pull chains as designed.
IF you have a wall switch for the ceiling fan and a separate one for the light, it is simply a matter of making the connections for the light and fan to the proper wires going to the wall switch box. Typically, the ceiling fan's light wire (blue in most cases) is connected to the red wire in the ceiling box, while the fan wire (black in most cases) is connected to the black wire in the ceiling box. Connect the white wires together; and then the green and bare wires together for your ground and you should be set.
Remember to disconnect the power to this circuit by turning off the breaker before doing any wiring work.
I hope you find this Very Helpful and best regards!
Oct 11, 2009 | Dryers
Trailer break lights and running lights don't work
i would use a multimeter to read each wires operation voltage before hooking up. ex. turn on turn signal, connect meter to find which wires is pulsing.
So your saying you wired the trailer yourself? yes you need the wires to both sides for brake and running. the runners have to be all connected, and the brake all connected, hot and neutral.
Mar 17, 2009 | 2002 Oldsmobile Alero
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
